Question about Maytag MAV7600 Top Load Washer
Cold water button pressed but warm water comes out
The cold water button is pressed but warm water comes out?
  • 3,600 Answers
Try cleaning the screens in the inlet tubes on the back of the machine and clean out any foreign object in the screens and clean the valves where the water hose hooks up. Do this fist and leave a responce for more help.
Posted on Jun 14, 2009
Lavamac front loading 28kg commercial washing machine(coin operated). When I press "cold" wash, why is the warm water coming out?
Your washing machine has to release some warm water even when liquid detergent is used. The purpose of the brief release of warm water is to dissolve powdered detergent and/or flush liquid detergent residue.
Jul 19, 2017 | Washing Machines
Clean light flashes, don't start
Hi
Try pressing normalwash-heatdry-normalwash-heatdry-normalwash-heatdry-normalwash-heat then all the lights come on. Let run for a little bit. then keep pressing the start button. untell the unit shuts off, then try running a cycle.After all the lights come on, stop pushing buttons and wait. The unit will start up after a couple minutes The control board has a memory in it. So if you have cold water running in it one time. It will take longer to warm up. Your memory in the control board says its taking to long to warm up. Shutting down thinking their is something wrong with your heating cycle.
Thanks for contacting fixya.com
Oct 30, 2009 | Dishwashers
I DON'T GET WARM WATER, WHEN SET ON WARM, ONLY GET COLD
If the setting is only hot and cold, there will be no
warm water coming out. At warm setting if it is
present, it should give you warm water.
Sep 23, 2009 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Cold shots
Remove the portafilter and press the brew button is the water that is coming out of the head warm or completely cold? If cold then one of the thermostats on the boiler is damaged.
Aug 09, 2009 | Gaggia 102534 Espresso-Color...
No cold water is comming out of the cold water pipe, when I press warm/cold only the warm water comes out what could be the problem?
hi sounds like u could have self pluming taps on your hot cold pipes common for them to get blockd due 2 hard water need 2 replace taps or remove and clean holes out in old taps hope im right from washerman27
Apr 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Warm water out when cold only button pressed. need part # for water solenoid
u can call any maytag store they can look up part but u can use the universal valve part no is 205613
Apr 16, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Cold button is pressed and warm water comes out
water valves might be wired wrong or water select control is bad or wired wrong
Apr 10, 2009 | Maytag Atlantis MAV7551 Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My Atlantis Oversize Capacity Washer is the problem.When I select a Warm/Cold wash the water starts out warm, then kicks into hot water. So then I have to hit the Warm/Cold button over and over as it fill...
The temp is controlled by a thermistor to make sure the warm water is warm. If the incoming cold is too cold, or the incoming hot is not hot enough, it will compensate by turning off the cold until the temp comes up, then it should turn the cold back on. Make sure the hot supply is to the hot water valve. If the hoses are backwards it won't work right either. Or you may have a bad solenoid in the water valve. It's possible for a water valve to work when it's cold, but as electricity runs through it, the solenoid heats up and causes it to open electrically which will close it mechanically and turn the water off. Usually if this is the case it won't open again for at least 10 minutes until the solenoid cools down enough.
Jul 21, 2008 | Maytag Washing Machines
The water will not come out cold, it is warm or hot. This washer has an automatic temperature control button.
just a possibility but have you the hot and cold hoses the wrong way round assuming it is a two fill hose machine. way to check is to select rinse and put you hand in the water coming into the drawer. if it is warm, then hoses are wrong way round
Jun 29, 2008 | Maytag Washing Machines
Maytag MAV7600 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
