Question about Gateway MT3705 Notebook
Vista will not boot
Virus attack closing any access to laptop, threatening to format harddrive... How to recover and restart
    Problem Solver:
  • 10 Answers
Shutdown and then take your hard drive out, connect it to another PC with a USB adapter/cable, and use that other PC's anti-virus (e.g., McAffee) and anti-malware (e.g., malwarebyte) to scan and clean your hardrive. Make sure your hard drive does not overheat during the scan/cleaning process. After cleaning, re-insert hard drive in your laptop and boot.
Posted on May 12, 2014
Boot mgr error
This message usually means your "boot record" on your harddrive is corrupt due to a virus attack or harddrive failure. You will need to repair your boot record. If that doesn't solve the problem, replace your harddrive. If you don't know what this means, take it to a good computer repair shop. It's not something you want to do as a "newbie".
Oct 13, 2013 | Computers & Internet
Boot device not found, insert a boot disk and press any key
The "no bootable devices found" error can create headaches, as well as occasional heartache if you're a laptop user. This error appears when your computer is unable to find a device or file required for normal operation. It could indicate one of three issues: hard drive failure, software error or motherboard malfunction. Any of these potential problems can render your laptop useless. Hard drive failure or software errors can lead to data loss, which can cause anguish and catastrophe, depending on the files business information, family photos, student projects at risk.
Hard Drive Failure
The interior of a hard drive is akin to a turntable. Most hard drives contain two to three discs, known as platters, which are similar to records. These platters are read and written on by a tiny needle called the read/write head, similar to the arm and needle on a turntable. When a hard drive functions properly, the platters spin and the read/write head accesses the files necessary to boot your computer. Improper function of any of these physical pieces can cause a mechanical failure and result in the "no bootable devices" error. Software Error
In rare instances, a software problem more specifically, a particularly nasty virus may cause the "no bootable devices" error.
Most often, if a virus attacks and corrupts your system, your computer can still detect the hard drive and operating system, and you'll see some attempt at a normal boot.
If a virus attacks certain system and startup files, however, they may not be detectable next time you boot your computer, thus causing you to see "no bootable devices."
This may also happen if you are manually deleting files from your computer and accidentally delete system files.
Motherboard
Sometimes individual components of your laptop's motherboard malfunction, which can cause problems ranging from loss of wireless capabilities to inability to detect an external power source.
If the components that detect your hard drive fail, your laptop is unable to receive signals from the hard drive and therefore may display the "no bootable devices" error.
Repair
Fixing a "no bootable devices" error can prove costly.
If motherboard failure caused the error, you're probably better off purchasing a new laptop; unless it's under warranty; the average motherboard replacement costs $250 to $500.
You can reinstall your operating system to resolve software errors, which is fairly inexpensive by computer repair standards, costing $80 to $130 dollars, but this step may also overwrite your existing data.
In some cases, data may prove so badly corrupted it's not salvageable.
If you can recover it, however, that raises your repair costs. additional fee.
If hard drive failure caused your "no bootable devices" error, you can replace the drive.
If you need to recover data from a malfunctioning hard drive, send it to a clean room for recovery.
In a clean room, technicians disassemble your hard drive and image each platter; this kind of data recovery is extremely expensive, costing up to $2000 depending on the work involved.
Prevention
There is no way to guarantee you will never receive a "no bootable devices" error, but there are some steps you can take to help prevent it from happening.
Keep your laptop on a flat surface when using it, and avoid any bumps that may cause the hard drive's read/write mechanism to lock up.
Avoid transporting your laptop while the hard drive is active; turn your computer off while traveling.
Additionally, regularly run an anti-malware program to catch and remove viruses or spyware before they cause system problems.
http://www.upgradenrepair.com/Issues/N/nobootabledevicefound.htm
also you might
HP laptop no bootable devices found
Turn on your HP laptop with Windows Vista or Windows 7 and press the "Esc" key repeatedly to access the startup Menu. Press "F10" to access the BIOS.
Press "F9" to restore the BIOS to its default settings. Press "Enter" to verify that you want to restore the BIOS default settings.
Press "F10" to save your changes and exit the BIOS. Press "Enter" to confirm that you want to save the BIOS changes and continue booting up the laptop.
HP Hard Disk Test
Hold the Power button down for 15 seconds when the laptop is turned on to turn off the laptop.
Press the Power button again to turn on the laptop and press the "Esc" key repeatedly to access the startup Menu.
Press "F2" to access the System Diagnostics.
Click "Hard Disk Test" to begin testing the hard drive.
If "Pass" is displayed after all of the tests then the program fixed the error.
If "Fail" is displayed after any of the tests, proceed to Section 3 if you are using Windows Vista and Section 4 if you are using Windows 7.
Recover Windows Vista Factory Settings
Click "Start," "All Programs," "Recovery Manager" and "Recovery Manager" again to open the HP Recovery Manager.
Click "Advanced Options," then click "System Recovery" and "Next."
The laptop will restart and will boot up to the HP Recovery Manager.
Click "System Recovery" and click "Next."
Click "No" when asked if you want to use Microsoft System Restore and click "Next."
Select "Recover without backing up your files" and click "Next."
Click "Next" to begin the recovery process.
When the process is finished the laptop will restart and boot to the Windows Vista setup screen.
Recover Windows 7 Factory Settings
Click "System Recovery."
The laptop will restart and will boot to HP Recovery Manager. Click "System Recovery," then click "Next."
Click "Recover without backing up your files" and click "Next."
When the process is finished the laptop will restart and boot to the Windows 7 setup screen.
Jun 26, 2013 | Acer Aspire One PC Notebook
Need to format laptop computer as I am suspecting a virus attack. I am unable to open files, and does not show drives.
You can reformat your computer by using your recovery discs. Please keep in mind that if you reformat your computer you will be unable to recover any of your files that are currently on it. If you are able to, backup everything you can. You can use an external harddrive or a flash drive to get files off if you boot from a Linux LiveCD if you have access to a working computer with a CD burner and a CD. Post back if you need any help with that.
Mar 02, 2011 | Toshiba Satellite A135-S2276 Notebook
Fujitsu Amilo Pro V2055. Starts boot, performs RAM check, etc. then displays "cant find operating system". Checked that HDD is ok by reading it using another computer. Tried hard disk utility...
This usually means 1 of a few things..
1. Your Harddrive is bad
2. You got a boot sector virus, and your boot ini file is so badly infected, your computer can't find the boot file and you need to format your c:\ or d:\ drive....if you can get to your CMD window (command) but the way you bring it up is from CMD in start/run/CMD but since you can't even boot to your desktop...then you can choose a few options..
IF you have your your Windows Xp, or Windows Vista or Window 7 (depending on how you purchased your system, I'm thinking XP...since with Vista and Windows 7 you can reload to factory settings)
If you do have the disk....then you WILL have to reload your Operating System ....IF your harddrive isn't bad (have bad sectors or clusters) or is just "old" or was bumped severely and there's a dent on your harddrive preventing your boot ini file from being found...
There are so many things that could be wrong with it....Send me more infomation....
It's definitely NOT your motherboard...it's a harddrive issue...whether from a virus (which there are many out there that could infect or even rename your boot file....or your harddrive is BAD..
Either way...let me know and I can help you further!!!
Dec 02, 2010 | Fujitsu AMILO PC Laptops
Mybook essential edition- won't boot up & showing the message: F:\ is not accessible. The parameter is incorrect.
looks like a drive letter conflict, go into disc management.. right click my computer (computer in vista or 7) / manage / disc management. righr click on your drive and choose change drive letter and paths
Jul 01, 2010 | Western Digital My Book Essential 1TB...
STUCK ON START PAGE,CAN'T GET TO DESKTOP
Most likely a Windows software problem. Could be virus caused. Try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options.Use the arrow key to select "boot using last known good configuration". If that works, you're done. If not, try restarting the laptop and immediately start tapping the f8 key until you see a screen with several boot options. This time select "boot in safe mode". The laptop screen will look different but will still allow you to run your laptop. Click on the "Start" button, then "Help and Support" and then "Undo changes to your system using system restore". Click on "Restore" and then select a date shown in BOLD when your laptop was running fine. Have the laptop restore to that date. After restarting, you should have full functionality. If this doesn't work, you may have a failing harddrive. Try reinstalling Windows. If it fails during loading, your harddrive is most like failing and should be replaced. If reloading solves the problem, you had corrupt software probably caused by a virus attack.
Sep 07, 2009 | Dell Inspiron 1525 Laptop
HP DV4 displays only a blue screen running vista
Shutdown the computer,disconnect external peripherials.
Turn on the computer and hit F8 key as soon as you restart the computer
You will get the windows advance options menu.
Select the Safe mode option and hit enter.
If the computer boots in safe mode, do a system restore to previous date.
If computer restore then issue is resolved.
If still unable to boot in safe mode.
Ran a harddrive diagnostic.If harddrive test passes. If harddrive test fails replace harddrive.
Boot the system using the windows xp or vista operating system disk. Try to repair the OS then reboot the system and check.
If still unable to boot possible issue with corrupt operating system.
Reinstall Operating system. / Recover System . Good Luck.
Aug 27, 2009 | HP Pavilion dv4-1140go Laptop
Dell Inspiron6400/E1505 restarts automatically after shut off
The problem of your laptop is that once it has been attacked by a virus. In that very case that virus may be removed but the damage it has made to your OS cannot be restored unless you format your laptop with Windows XP/Vista.
Or next best reason may be problem with your laptop RAM.
You should quickly consult a good hardware engineer for sough ting your problem out. Bye
Feb 23, 2009 | Dell Inspiron 6400 Notebook
Mobile is Restarted
as u cleared thatur phone is restarting after display date it was attacked by the virus,so to recover the problem pls go to the nearest service shop n get the phone formatted
Dec 20, 2008 | Nokia 5310 Cellular Phone
Gateway MT3705 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
