Question about B&K Plumbing
Have b & K frost free antisiphon hose bib that leaks out of seal
I have a b & K frost free anti siphon hose bib and the ani siphon seal is leaking like crazy and I cant find a replacement Please Help!
  • 62 Answers
You can replace with any brand frost free faucet.Parts are impossible to get.
Posted on Jun 15, 2009
  • dbtbird57 Jul 27, 2013
    I replaced mine with a new anti siphon kit from Home Depot. It was like 4 dollars.
    Problem Solver:
  • 8 Answers
You can get new kits for like 4 dollars at Home Depot. They are all the same for each different brand.
Posted on Jul 27, 2013
When I hook my cold water up to the back of the washer it leaks. Its not the hose its the actual bib on the back of the washer. Is this replaceable and where do I find one?
if ur talking bout the water inlet valve the whole thing needs replacing. however highly unlike it has any parts that would leak? other than someone putting on the hose improperly and damaging the threading? perhaps u may want to take a closer look at ur hoses and make sure it has the rubber seal in side it?
Feb 21, 2015 | Maytag Centennial Series MVWC200XW
Frost free faucet B & k 1019 needs anti siphon replacement part
I would search on line, if you already havn't. Otherwise a replacement faucet is $20-$30. turn the water off inside the house, drain the line, and use two wrenches to remove the faucet, (one to hold the pipe and one to turn the faucet).
Feb 07, 2014 | Welding Tools
I have a Mueller sillcock quarter turn anti siphon frost free faucet I picked up from Home Depot last Fall. It worked through the Fall and the Spring up until a few days ago. It no longer turns on. It
The seals are probably stuck inside causing it not to open. Turn the water off to the spigot. Unscrew the head of the faucet, behind handle. The whole inside assembly comes out. You can then replace the gaskets and reinstall the assembly.
RJH2O
May 11, 2013 | Plumbing
No i don't just trying to help a elderly lady
It's not the sprinkler. The valve is not seating completely. You will notice the sprinkler it is leaking from is the lowest one in that particular zone. Don't take it out on the sprinkler it's not his fault. Think of it as if you didn't shut a hose bib off completely the leak doesn't drip at the bib it shows up at the end of the garden hose. Same principal. The valve is the hose bib.
Apr 17, 2013 | Rainbird Rain Bird 1806nsi Pop Up No Side...
Water leak ge clothes washer
Replace the anti-siphon valve
Anti-siphon valves prevent water from siphoning back into the water supply. Also known as vacuum breakers, anti-siphon valves are used on washing machines, faucets, toilets, sprinklers and other water sources. A leak on an anti-siphon valve can cause deterioration of the appliance's external components and damage the flooring material underneath the washing machine. Therefore, a leaking anti-siphon valve should be attended to as soon as possible.
Jun 08, 2012 | GE WBSR3140DW Top Load Washer
Cant get hose bib off pipe for leak replacement?
Follow it through to the inside and replace the length of pipe complete from rising main to the outside tap.
or
They are normally soldered on, so you need a blow torch.
You probably only needed a 5 cent washer, or gland packing in the top.
Dec 12, 2017 | Plumbing
My frost free kenmore upright freezer collects frost around the top where the light is. I have checked the door seal and there seems to be no leakage. It is less than 2 years old
if frost free is collecting ice any where ther is a air leak . ck for poor seal.s seals sometime look good but not sealing . use a $10.00 bill a five won't work close the door on it in several places and ck the tennison . on tennison / bad seal /.. mm
Aug 11, 2010 | Refrigerators
I have a 1990 honda accord EX and recently have had anti-freeze leaking out. I replaced the heater hose where it was leaking from and now its leaking from somewhere else. It does not leak when I drive only...
If the rad hoses and heater hoses are more then 5 years old it could be leaking from any one of them. The pressure build up when the engine is stopped. I would use a coolant flush, change the antifreeze, all the other hoses and use bars leak to seal any small leaks
Jul 26, 2010 | 1990 Honda Accord
How to properly install and insulate a new hose bib
Get yourself what is called a "Frost Proof" hose bib. This puts the shutoff valve in the assembly well inside the cellar so insulation will not be a concern. I believe they come in two different lengths so get the longest one. Make sure you have a shutoff installed in the supply pipe (it should already be there) so you can shut off the water completely to the hose bib. Hope this helps.
Jun 08, 2010 | Plumbing
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
Plumbing Logo
1,112 people viewed this question
Top B&K Plumbing Experts
Tom Chichester
Bill Boyd
Daryl Gleaton
Are you a B&K Plumbing Expert? Answer questions, earn points and help others
