Question about Samsung 300E Notebook
Notebook 300e os wont start
Have an orange light on the front 4 lights is orange and screen says preparing aoutomatic repair and that's it
Monitor running but screen not coming on and the front orange light is blinking like if sleep
If no message comes up it is a really serious problem, probably might be your motherboard.
If you have a Windows installlation disk, try to boot it up with it - don't install windows, just to test if it boots, though I'm quite pessmistic about it doing anything.
If falis, simply take it to a repair shop and cross your finger that they can repaird it
May 09, 2015 | Acer C720 Chromebook Gray 11.6" Notebook...
Why does my screen keep going black on my Acer Chromebook c720?
Try checking the lights on the front of your laptop, are any indicator lights on? I have an older Acer Extensa, but the quickest way for me to identify what its probably doing is that if I see two different colored lights I know that; 1. a green light means there is power to the laptop so more than likely it isn't actually off or all lights would be off, 2. if I see an amber/orange light on the front or near the power button its in a power setting mode, which means its either hibernating or sleeping. You can usually wake it by quickly tapping the power button or tapping the enter button, depending on your laptop you may have options hot keys on the keyboard. If it wakes by doing any of those things then check your power settings to see if you have it set to sleep or hibernate.
I have Windows 7, I left click on the start/ lower left Windows Icon on the task bar/control panel/performance and tools/ then on the left side list, power setting options. Or just click start and in the search box type power options, you'll see the direct link under the control panel section. I hope that helps. Try running troubleshooter too
Mar 04, 2014 | Acer C720 Chromebook Gray 11.6" Notebook...
Toshiba L655s5065RD wont start , only sign of life is blinking orange light
Okay, what does that light indicate? (hard drive activity, power plugged in, battery, etc). It most likely indicates a faulty power supply or damaged battery unit.
Dec 10, 2012 | Toshiba Satellite L655S5065RD 156 Notebook...
The orange light shows on the computer and soon as I cut on the computer it loads then freezes please help me
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 17, 2011 | Compaq Evo Notebook N400c
I have a nissan march 2003 model japanise make aoutomatic transmission and yesterday the amber/orange light came on and is still on what does this mean
You have to get a diagnostic code with a qualify technician. Do not drive your car to far if light is blinking.
Aug 16, 2010 | 2002 Nissan Altima
Will not start up
try to reformat it if it will still not work. ask a technician. maybe there's a problem in your hardware.
May 02, 2010 | Dell Latitude 120L Notebook
MY COMPAQ PRESARIO c502us HAS A BLUE SCREEN & WONT START
You need to repair your operating system (OS), using your OS installation CD.
OS repair wont loose your data, it will simply repair and correct your errors
Dec 30, 2009 | Compaq Presario C552US Notebook PC
Computer on, screen blank and wireless unresponsive
YUP... sound like a motherboard problem. Could be a short somewhere. Try taking the Battery out and also the hard drive and put them back again. I have fixed such problems before by doing just that. GOOD LUCK !!
Jul 06, 2009 | HP Pavilion dv9000z Notebook
Dell inspiron 1100 wont stay on
Normally the battery light will rapidly flash orange if the battery is defective. It will alternate between orange and green if it is too hot to charge. Or it will either flash orange or be a steady orange if the battery is low or completely discharged. Based on this and the fact that you cannot get it to stay on for more than 7 seconds, I would have to say that you need to recharge the battery by plugging the laptop into an AC outlet. After all, it can't run without the juice.
Apr 14, 2009 | Dell Inspiron 1100 Notebook
Acer aspire 9300 laptop
Right click anywhere on the desktop, open the screen saver tab, click on the power button at the bottom. You'll see a box that reads monitor, set this to never. That should take care of the screen shutting down. As far as the orange light, I'm guessing that's the battery light, and it's time for a new battery.(It should be green and flashes orange when the battery no longer works properly)
Jun 12, 2008 | Acer Aspire 9300 Notebook
Samsung 300E Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
