Question about LG LRSC26910 Side by Side Refrigerator
How to replace button assembly on lg lfx25975st
How to replace water button assembly ABH37000107
How to adjust water fill level to icemaker on LG LMX refrigerator
If it is not on the ice maker unit itself, the machine does not have an adjustment. LG Ice Maker Assembly AEQ36756901
Jun 19, 2016 | LG Refrigerators
Changed the filter but water is coming out slow from the water dispenser
Most likely your water flow is restricted by Ice build up within the small reservoir located in the refrigerator section. If that is not a problem then you could have a flow valve that's not opening fully.
Jul 25, 2014 | LG LFX25975ST (247 cu ft) Side by Side...
LFX25975ST water coming out slow
check if the water supply main valve for the unit is fully opened. if it is , check for obstructions in the line. if waterline has no obstructions , find out if water solenoid valve is working fine. with all the mentioned working alright but problem is still present , call a service man .thanks.
Apr 23, 2014 | LG LFX25971ST Bottom Freezer French Door...
Lg tromm wm2277hw will not spin
Press the SPIN SPEED and SOIL LEVEL buttons simultaneously to enter QC test mode and check the frequency of the water level, if the display shows 248 or more:
NO: Check the sensor switch assembly and also the pressure hose, replace either if faulty.
YES: Press the START/PAUSE button twice while in QC test mode and check whether the drum spins at low speed, this is normal.
If no reaction from the drum at all the the main PWB assembly board will need replacing.
Feb 09, 2014 | LG WM-2277HW Front Load Washer
I have a LG fuzzy logic the problem is that its not stopping the water input its over flowing ....
When you press the "SPIN SPEED" button and "SOIL LEVEL" button the water level frequency should be above 246. If the water frequency level fails to reach 246 in 8 minutes you will get an IE error or inlet error. You would need to check the water valve, water pressure, etc.
How does the machine know if the water level is complete? Water level switch right? So obviously the control is timing the amount of time it takes till the water level switch kicks off. If it takes more than 8 minutes we have a problem don't we? Therefore if something is partially blocking the tubing from tub to switch that might throw off the water level switch. It is located on the main control assembly and has the rubber tube connected to it. The control board uses this to determine water frequency level. Just blowing the sediment out of that tubing will cure the IE error IF everything else mentioned is all good. I meself would do that first before replacing any parts.
LG WASHER MANUAL
Aug 04, 2012 | LG Washing Machines
LFX25975ST ERROR 1F.
needs longer to defrost water line in the door turn it off again and use a hair dryer on the door
Mar 27, 2012 | LG LFX25975ST (247 cu ft) Side by Side...
I open the frige and no light or compressor sound. I checked the power source and no issues.... how do i reset the power board control ??
http://appliancedigest.com/index.php?/files/file/135-lfx25960xx-lg-247-ft-french-door-refrigerator-with-ice-in-door-service-manual/ Closes I found.
Nov 15, 2010 | LG LFX25975ST (247 cu ft) Side by Side...
Our LG model WM2032HW intermittently show up with th FE code what could be wrong and can it be fixed by us?
FE error code means water is overflowing. The water is over 8 level.When FE is displayed, the drain pump will operate to drain water automatically. Otherwise the pressure switch assembly is malfunctioning. Check and replace if necessary. Part number is 6600FA1704X.
The pressure switch assembly shuts off the water inlet valve when the desired water level is reached. It then activates the drain pump when the water inlet valve is not deactivated.
Oct 18, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
LG LRSC26910 Side by Side Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
