Question about FM Manufacturing FM Optics Magazine Tube LED Flashlight for Remington 870 Black
Changing battery on FM optics shotgun laser
How to change a battery on a FM Optics shotgun laser?
Optics not working can not see anything through the optics, have changed the batteries and optic is making a humming noise
Hello, first did you install the batteries with it polaity the correct way. Negative - to spring side of the battery compartment. Postive + to the small flate plate. The hum could possibly be a shorted coil. When the short occurs, the electron leakage across the winding it will start to hum. Then the coil will completly burn out. stewbison
Feb 28, 2011 | Night Owl Optics Explorer NOCX3 Monocular
My lg home theater plays cds clearly but does not play dvd
change the motor disc spindle because are out of velocity
Dec 08, 2009 | Televison & Video
Disassemble a remington 11-87 super magnum
Go to the link below to get the manual. In the manual it will tell you how to disassemble the shotgun. It starts on page 14.
http://www.scribd.com/doc/12887293/Remington-1100-1187-Super-Mag-Auto-Shotguns
Good Luck
Nov 01, 2009 | Remington Shotgun Mount 12Ga Lh, B Square...
Insignia portable player NS-8PDVDA not working
Here's how I've solved same symptoms with our NS -PDVD8a:
1. Cleaned laser optics with isopropyl alcohol/swap --make sure you let the optics dry/IPA evaporate from the optics before running
2. Using compressed air can--cleaned laser track
3. Gently move laser along track several times - it seems laser is having most trouble at start of disc -- not sure it needs lubrication, but running it along track several times seems to have righted it
Had to do this a couple of times, but it's working now -- expect I will need to do this again -- no idea how long fix will work.
Nov 22, 2008 | Insignia NS-8PDVD
FM Manufacturing FM Optics Magazine Tube LED Flashlight for Remington 870 Black Logo
Top FM Manufacturing Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a FM Manufacturing Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
