Question about Dirt Devil Jaguar Pet Upright Bagless Vacuum
Assembly I think im missing a screw
That is not a problem it will run without it
Posted on Mar 24, 2014
Miele S5000 Cat & DoG - I need to access the motor housing because it sound like there is something flapping in there
Hi There,
You are probably missing the screw under the circuit board or filter assembly. THe miele S5311 is pretty similar and I have made a video showing how to pull it apart. Hope it helps - Alec
Feb 23, 2013 | Miele Vacuums
How to replace central vacuums Carbon Brushes
The entire brush and holder assembly has to be purchased/replaced. That's the plastic piece that screws on to the motor. I don't think you can even get brushes for their machines anymore.
Remove screws. Remove plastic piece from motor. Replace.
Oct 17, 2010 | Electrolux Central Vacuum
WHERE CAN I GET A INSTRUCTION GUIDE FOR THE BISSELL PRO 2X MODE95
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tyui
Jun 21, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
Eureka 4870 hose assembly replacement
Boy, it's been awhile since I took one of these hoses off, but I think at least one of those plastic hose guide things has to come off in order to remove the hose. Those screws that look like they cannot be removed are probably torx screws which need a T20 torx scredriver that you can get at any hardware store. That is the most common size torx screw that Eureka uses.
Here is a link to the owner's manual in case you need any diagrams for getting the clear tubes off:
http://www.eureka.com/service/manuals/70750.pdf
Hope this helps. :-)
Oct 17, 2008 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover wind tunnel + cyclonic
im pretty sure there are a series of screws that hold it together ( look down into the bottom of it ) once those are all out then it should just pull apart. be careful if it fights you than double check for any other screws you might have missed, they don't make them easy to find.
Sep 21, 2008 | Hoover U5753-900 WindTunnel Bagless...
Hoover SteamVac Dual V Carpet Cleaner # F7410-900
"I did some research online and the recurrent theme was a bad turbine assembly. Fortunately I was able to fix this myself which took about 2 hours (some reading) and little effort. The problem was with the turbine which is fairly simple and had a bearing that had rusted and froze up. Removing the cover proved to be more difficult than fixing the stuck bearing. This was mostly due to figuring out the correct screws to remove and finally discovering that the back of the cover (over the wheels) is not secured by fasteners but by pegs that "pop" out.
Once I had the brush assembly and Cover removed the turbine came out with the removal of some obvious screws and gently pulling the hoses from the assembly. After carefully opening the assembly housing I discovered the bearing problem and with a little lubrication and some new grease had it working in short order. Putting everything back together was simple as well."
this worked for me. although once i got in i just had to mess around with the gears and loosen them up. getting in was the hard part soo here you go peoples.
take off tanks
unscrew 6 screws fom underneath machine. look carefully
just underneath where the dirty tank goes right by the part that sucks everything up is a screw. unscrew it
pop off the switch for your spin scrub mode. it pops right back on.
make sure your locks for the tank are turned in
then the back just pops off. you might have to give it a good tug. there are no screws although it maight look like there is.
then pull off the grey part.
once inside it is pretty easy.
but if you have any questionbs email at lostnhisblueyes@aol.com
i took off so many more screws than i needed to to get this figured out so dont do that.
Feb 23, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Belt
Turn vac over, take out 4 to 5 screws and the top cover will come off. The belt is a cogged belt #72393 and goes between the brush roll motor and the brush roll.
Nov 14, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Kirby G3 - jump - skip problem
Hi, Try logging your post on the Kirby Trading Forum at Kirbydirect.co.uk - you'll be sure to get a reply. John
Jun 12, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Dirt Devil Jaguar Pet Upright Bagless Vacuum Logo
20 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
