Question about Proscan Televison & Video
Lw-crt tv scans but no channel displayed
It scans but no signal
    Top Expert:
  • Proscan Master
  • 74,666 Answers
Main system control memory IC fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Posted on Mar 24, 2014
2 Suggested Answers
SOURCE: my tv sound ok, crt high voltage ok,channel number display ok
check for a resistor rated around 220kohms somewhere around the flyback area. i have never worked on this model tv before so i cant give you an exact part number on the board but had the same problem with sharp tvs
Posted on Nov 21, 2008
Accidently changed something and not able to get antenna tv now - do not ahve cable here at work
I am unable to see at a glance how to correct this but it is between its menu, channel and volume buttons to alter the settings it may be worth to run through the re-tune sequence below?
To preset a channel or to change a preset channel, follow the procedure below.
1) Press the POWER button to turn on the TV.
2) Press the MENU button so that the menu display appears
on the TV screen.
3) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
Then, press the VOL(ume) ? button.
4) Press the CH(annel) ? or ? button to point to "AUTO PRESET CH".
The tuner scans and memorizes all active channels in your area.
? The TV distinguishes between standard TV channels and cable channels.
? When AUTO PRESET CH action is completed, the lowest memorized channel reappears on the
screen.
? When you press the CH(annel) ? or ? button after selecting "AUTO PRESET CH", the tuner
will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by the receiving conditions. In this
case, try AUTO PRESET CH action again in the fine receiving conditions.
? When AUTO PRESET CH is activated where there is no TV signal input,"NO TV SIGNALS"
will appear on the display after the completion of channel scanning.
[ADD/DELETE FUNCTION]
1) Press the MENU button so that the menu display appears on the TV screen.
2) Press the CH(annel) ? or ? button to point to "CHANNEL SET".
3) Press the VOL(ume) ? button so that "ADD/DELETE" is selected.
4) Use the CH(annel) ? or ? button to select the
channel you wish to put into memory or to erase from memory.
Note: The menu will disappear in about 10 seconds.
Perform "ADD/DELETE" function while this display appears on the
screen.
? Press the VOL(ume) ? or ? button to light up the channel number
in LIGHT BLUE if you wish to add the channel into memory.
in LIGHT RED if you wish to erase the channel from memory.
5) Press the MENU button to exit the menu.
Hope this helps.
Jun 29, 2015 | Durabrand DWT1304 13" TV
How do I put it on channel 3?
If you are asking about using a standard CRT Monitor with some device that has a Channel 3 TV output, you have to either have a tv tuner device between your monitor and the device you want to connect to, or find video outputs on the device other than the TV channel out in order to connect to a monitor. Monitors work with video signals. TV's work with radio signals. These two inputs are not the same thing. Channel 3 is a specific radio frequency signal that must be converted to video to be displayed by a TV. Computer monitors do not have the circuitry installed to convert radio frequency signals to video. Therefore, strictly speaking, there is no easy way to 'put' a CRT Monitor 'on channel three'.
Apr 25, 2015 | Televison & Video
How to tune in Channel 60 in a Sony Triniton CRT?
assuming that you can "pick up" channel 60..and that the signal is strong enuff...that is part one..make sure you have a good antenna connection and that the antenna is positioned for maximum pick up, then do the scan mode on the tv via the remote control. it will re scan the channels and if the signal from channel 60 is being picked up strong enough, it will program the channel into your set automatically.
Sep 03, 2014 | Televison & Video
HOW DO YOU GET CHANNELS REPROGRAMED INTO THE TV?
Hello
Auto presetting channels you wish to know I thinks, if so do the following.
on the TV screen.
? The TV distinguishes between standard TV channels and cable (CATV)
channels.
channel reappears on the screen.
the tuner will stop at the memorized channels only.
? The TV may recognize TV channels to be CATV channels by receiving conditions. In this case,
? When AUTO PRESET CH is activated where there is no TV signal input, "NO TV SIGNALS"
OK.
Jan 11, 2011 | Emerson EWF2004 20" TV
How to scan channels
The TV user guide should provide the procedures of acquiring auto scan. For example, your TV may be acquiring functionality from satellites dishs or cable receiver devices. Performing an auto scan achievable with the remote control device with adjustment to settings on the channel buttons would produce a signal only with available transmitter stations. Performing a channel auto scan would display no signals without available receiver devices often acquired with susbscription from a provder either cable TV, sattelite or disk network, show on demand for example. However, performing an auto scan on a new Tv should simply display a count list of possible available channels on which signals could be display when any is provided. Good luck
Jan 08, 2011 | Toshiba 32AV502U 31.5 in. LCD HDTV
What buton do press to get the channels?
Hello
To tune the TV either with cable of trerrestrial antena, plug in the cable or terrestrial antena cable to the antenna socket of the TV and do the following.
on the TV screen.
channels.
OK.
Dec 16, 2010 | Emerson EWF2004 20" TV
We can't get any of the channels don't know where to start from menu area
Hello
You just do autotune to receive all channels. In this mode TV will tune through the entire channel band automatically, and finally will stop tuneing, and will show the first channel receved. You must be patient for these time. about two or three minutes, without disturbing is process. The tuning process follows.
Auto Tuner Setup
In Auto Tuner Setup, the TV automatically scans
t h rough all available channels, memorizing the active
ones and skipping over blank ones or channels with
weak signals. This means when you scan (using the
CH A N N E L +/- b u t t o n s ) you will receive only clear,
active channels
P ress the ME N U b u t t o n
Press UP or DOWN buttonTo AUTO TUNER SETUP
Press Right or Left button to operate
Press Vol+ or Vol (--) to choose CABLE or AIR
Press UP or DOWN button to move to START
Press Right or Left Button to start Auto Tuner Setup
Tv will show "NOW PROGAMMING" display.
Programming will take approximately 1 to 2 minutes.
After all it will show
PROGRAMMING OVER
Some cable systems experience interference from radio frequencies on cable Channel 95. You may delete this channel from
your scan by removing the "X" next to it on the Channel Summary screen.
Nov 29, 2010 | JVC AV-27120 27" TV
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. surfpro@yopmail.com
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Jan 06, 2009 | JVC AV27F476 27" TV
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
