Question about Tascam DP-008EX Pocketstudio Digital Multi-Track Recorder 8-Track
No vocal in mixdown
I'm trying to add vocal to a recorded song and then Mix it down so as to make a Master. I go into Mixdown mode and it does the Mixdown (I guess) but no vocal is in the product.
3 Suggested Answers
dj_relly999
  • 4070 Answers
SOURCE: I have the 24 track Neo Digital Portastudio. I
Hi and welcome to FixYa!
May I ask if you have stored several songs on the unit? You may need to free some data or recorded songs for you to record a new one. If the files are all free but still you can't record then the problem can be on the unit itself. It may have reached it's break point and the only cure is a reset from the dealer.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Nov 28, 2010
dunnbiker
  • 8546 Answers
SOURCE: on my tascam 2488 neo,
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Posted on Feb 20, 2011
How to record with Multi-effects feature on Tascam DP 01
I'm not familiar with the Tascam DP-01 but many multi-track recorders don't commit effects to the track until the mixdown phase. The thinking being that you cannot eliminate a "bad choice" effect once it's down to tape (old school term) and so they allow adding the audio tweaks at the final stages of recording. Here they hope you can appreciate the entire mix and then decide what sweetners to add.
Feb 21, 2013 | Tascam Audio Players & Recorders
I have a Tascam DP-02 8-track all-in-one digital recorder. I've successfully armed and recorded Ch's 1 and 2 to input A and saved the session. When I loaded the session the next day to resume the project,...
i had a look for u on the net only the small yellow ones light up but ill get back to you about the other question as soon as i find a ansew wont be long thanks from chris
Sep 14, 2008 | Tascam DP01 All-In-One Recording Package...
Hey. Im having a problem with my samson g track when mixing down midi and audio. The midi comes out really quiet even though its on full volume. It doesn't mixdown correctly. I'm also finding it impossible...
MIDI isn't audio, think of it as a sheet of music. It still needs to be played to be heard. Not sure of your recording setup but the midi performance that you have needs to trigger a keyboard or drum machine or VST instrument of some sort.
Apr 01, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
On my tascam 2488 neo, ive recorded a song that is 2min16sec. i set my in at zero and out at 2min23. i hit mixdown and then try to hit play and record and the record button will not light up or actually...
Jan 28, 2011 | Tascam 2488 Portastudio Multitrack...
Ikeep getting an error message when i go to mixdown/matering.it says that my tracks are too short,change outpoint. How do I change outpoint and to what do i change it to?Song is 4 mins. 23 secs long.
The 2488 requires a start point and end point in order to master down. The start point, by default is zero (the beginning of the song) so you will NOT have to create one, HOWEVER, you MUST provide an end point. The end point is wherever you wish the song to end, so, roll the BIG wheel to the end of the song, then, press LOCATE SET and OUT simultaneously. You have just now marked your out point and thus it will master the whole song. NOTE: If your song is 4:23, then the out point will be/should be a bit longer (a second or two- or even more- that's up to you) than that depending on where the song/music actually begins after the zero mark, therefore, make SURE you roll the BIG wheel enough to encompass the WHOLE SONG. The counter will reflect the time/length as a result of how far you roll the wheel. I hope this helps. One last note, do ALL this at the MIXDOWN prior to MASTERING.
Feb 22, 2010 | Tascam 2488 Portastudio Multitrack...
Very low output volume from Presonus Firebox recordings
i do'nt know the name of the sound driver installed in my PC
Jun 30, 2009 | PreSonus Firebox 6x10 External Sound...
Can't export song as audio mixdown on Cubase SX
I had this same problem, only it was after a reinstallation. Fixed it by changing the Output in the Audio Mixdown settings box to
"BUS 1 (Stereo)".
Jun 14, 2009 | Steinberg Cubase SX3
Altering an mp3 track
hi,
If you simply want to overlap the voice, you can do that by recording using any free softwares available on internet (just google free recording softwares)
you can try, cooledit as well, one track will contain your file with play mode, one track with record mode (for your voice)
then start recording, it will play the song simultaneously with recording your voice.
After then, you have to save the mixdown.
other long way is, you have to get KARAOKE for that song (karaoke means, no vocals only music track) then you'll get the recorded song in good quality.
Hope this helps.
Thanks.
May 11, 2009 | Apple Computers & Internet
Low Volume on CDs - Roland 2400 CD
Hey Rick, There are a couple of places to look; I'll assume you have a decent input level near -12db average without peaking. First, ensure during playback upper right meter labled MST is near peak without going over, if you have room push the master level above 0db to +1 thru +6db and recheck for peaks above 0db. (You never want digital recordings to hit above peaks, you lose quality or resolution of the sound) As you find the sweet spot, master rec to 23/24-16 using the elevated level on the master fader. The manual suggest editing and mastering with the master fader at 0db however if you don't compress your tracks individually or reprint them at higher levels, you may have a great mix at an overall lower volume, pushing the master fader should help for a quick fix, but if this cures the level issue, try compressing and leveling each track to peaks prior to the first mix only lowering tracks which are too loud, when you get to mastering, all your signals are at their top potential for the CD. Spend a few minutes burning samples at low, just below peak, and just above peak levels on separate tracks and playback in your boombox for reference to a commercial CD. You'll find little to no difference when you are in the sweet spot. Another trick is to mixdown to a separate pair of tracks (not 23/24-16) and compress again during master mixdown rec. (ultimately 23/24-16) Good Luck Jeremy Yates, Radio World LLC.
Jan 08, 2009 | Roland Vs2400CD Digital Workstation W/CD...
Tascam DP-008EX Pocketstudio Digital Multi-Track Recorder 8-Track Logo
69 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
