Question about Homedics Shiatsu Massager
Not working It was working fine then all of the sudden stopped in mid roll, now the remote doesn't come on, help!!!
13 yr old dishwasher suddenly stopped working mid pre wash. Water left in bottom of machine. Power point is fine. Will not start at all now though. No lights turn on either. Is it fixable ?
If it is 13 years old, it has most likely reached its end of life--whatever the cause, something has malfunctioned. However, a service technician would probably be able to advise.
Mar 16, 2016 | Dishwashers
When talking on my Blue parrot Bluetooth all of a sudden they can't hear me but I can still hear then. I have to switch mid-call from speaker back to Bluetooth for it to work again.
Replace lithium battery on remote seems once it goes below 3.1 volts system stops responding correctly so I have found.
hope this is of some help
Nov 21, 2014 | Cell Phones
Sharp lcd DVD error
Suggestion. Check the battery in the remote
Mar 21, 2014 | Sharp LC Televison & Video
Vauxhall Astra's remote suddenly stopped working.
Start troubleshooting by redoing the "mechanic's" work, making sure that the correct and unblown fuses are in the correct places.
May 13, 2017 | Cars & Trucks
My KLH 5100 System worked fine for nearly a year. Very suddenly the remote control seems to have no effect on the unit. It doesn't switch it on, or off, or change the volume...nothing. I changed the...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 08, 2011 | KLH R5100 Receiver
My lawnmover still cuts OK, but the propulsion doesn't work - it suddenly stopped mid-mow. I can't see anything immediately wrong with the mechanism underneath. Many thanks
plugged up jet in the carburetor does this. Starts when cold and eventually dies out
Have the jets cleaned and the float checked as well
Jul 09, 2011 | Garden
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half...
TV was working fine, moved to new home and the problem began. Picture rolls to the right, picture is fuzzy and will clear up somewhat at times. The picture will stop rolling at times also,but may be a half and half screen. Sound is fine, can you help me with this problem please.
Jun 23, 2010 | Sony KP-51HW40 51" Rear Projection...
2004 GMC Envoy XUV mid-gate window won't roll up
be sure the gate is fully closed or it will not roll up if it is firmly in place and still does not go up you will have to remove the cover and see if the actuator plastic has broken off from the switch, it also could be a bent rod and or the switch is bad. Check fuses as well just to be sure before going to all the other work to pull cover off. Hope this is helpful and thanks for using Fix-ya.
Jan 19, 2010 | 2004 GMC Envoy
Touchpad on Everex XT5000T suddenly stopped working
WHAT DID THE ERROR MESSAGE SAY
CHECK DEVICE MANAGER AND SEE IF ANY OF YOUR DRIVERS HAVE ? OR !
Jan 21, 2009 | Computers & Internet
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
Homedics Shiatsu Massager Logo
95 people viewed this question
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
