Question about Yamaha STAGEPAS 300 Portable PA System (Warehouse Resealed)
My yamaha 300 pa system is not working. when you turn it up the lights for a second lit and then nothing happens. please let me know what is the problem, thank you.
Yamaha 300 pa syhstem
Stagepas 300.Why does one of the mic volume controls, have to be at full level to hear anything through the speakers the others are OK ?
I would suspect the input jack on that channel is either bad or has a leg come loose from the circuit board.
Jun 04, 2016 | Yamaha STAGEPAS 300 PA System
What is the difference between a yamaha PA-300 keyboard adapter and the PA 301 ADAPTOR
For the best answer, call Yamaha directly. Here's the link-
Jun 17, 2015 | Yamaha Music
I use this for fitness classes. After 1or 2 songs -the music starts cutting out the power is still on the passport and i know my ipod is working correctly - what could be the problem ?
How is the iPod connected at the class?
The VIP channel will override the signal if a mic is connected.
Are you using the same cable for dance AND home?
Is the ipod getting interference at the class from a wi-fi signal?
See attachment. It might help. https://classrooms.at.ufl.edu/wp-content/uploads/portable-pa-system.pdf
Apr 21, 2015 | Fender Passport 150 PRO Portable PA System
Why does it cut out during a gig
Generally that indicates a power supply problem.
Mar 16, 2015 | Yamaha STAGEPAS 300 PA System
Yamaha Stagepas 300
short.. main out mosfets are damaged.
Sep 09, 2014 | Yamaha STAGEPAS 300 Portable PA System...
How can I set this up as fold back monitor? I have two AC60 and PA system. I want to use the rolands as fold back and wondering the best way to do this. PA system - Yamaha 3MX 312SC with two 200 watt...
Connect a jack cable from the monitor out on the Yamaha to the AUX IN on one of the AC60s. Then connect a jack cable from the MAIN OUT of the AC60 to the second AC60. Set the level going to the foldback by turning up the monitor control for each channel going in to the Yamaha. Be sure to switch on in this order: YAMAHA>AC60(1)>AC60(2). Switch off in the reverse order. Start with all volume controls down and bring them up to the level you need.
Sep 08, 2011 | Roland Ac60 Acoustic Chorus Guitar...
When the Peavey is turned on, the power LED and the 5 channel LEDs blink a number of times but other than that, nothing happens.
This MIGHT be a service manual for the amp portion of your unit:
http://elektrotanya.com/peavey_cs3000_4000_4080.pdf/download.html
Hopefully you can find a suitable service agency to repair this... If under warranty, take advantage of the warranty.
Mar 08, 2011 | Peavey Escort 3000 300 Watt Portable PA...
Dead nothing on display but power supply lead checks out okay 11.5 volts in nothing happens no power up or display PSRE 403 yamaha
If the power supply is NOT the original one, it may be reversed polarity.
The supply should be a PA-3C with the center being "+".
Sep 23, 2009 | Yamaha Music
Yamaha STAGEPAS 300 Portable PA System (Warehouse Resealed) Logo
16 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
