Question about Seagate Computers & Internet
Seagate Dashboard installation failure -
1152: Error extracting ...Temp\45C9181' to the temporary location
4 Suggested Answers
  • 27 Answers
SOURCE: I am trting to install
go to start then click on run. type in %temp% then click enter when the screen opens look for your device or whatever software or drivers you or it tryied to install and double click on it and it should finnish installing or open up for you.
Please rate my answer its much apreceted
Posted on Feb 13, 2009
  • 97 Answers
SOURCE: I am getting this error
1- Uninstall all the programes in control panel which you think you don't require
2- delete all leftover folders in program files outspark etc.
3- click start > run > type %temp% and delete ALL the files in that folder
( There will be like 3-4 u can't delete, dont worry about it ) also make sure you uninstall and delete the launchers.
4- Re download the PROGRAME ( INSTEAD of Saving it to DESKTOP, Save it somewhere else Like My Documents, Run it, And there you go problem solved.
At least that is how it worked for me, every time i was having that error i was saving it to desktop, after i did all the steps before and changed the location to my documents, it installed without any problems.
Posted on Aug 11, 2011
  • 105 Answers
SOURCE: I keep getting this error
step1:
Try deleting all the temp files in the temp folder.
Follow the steps to clear the temp folder:
Click on the start button and in the Search bar type in %temp% and hit enter
When the Temp folder opens up, press cntrl+ A and then press
delete
Posted on Oct 07, 2011
Tip
Cannot install a device driver by using its installation program in Windows...
ISSUE- You cannot install a device driver by using its installation program in Windows Vista
OVERVIEW-
When you try to install a device driver by using its installation program in Windows Vista, you are unsuccessful.
SYMPTOMS:
You may experience this issue if the following conditions are true:
• The driver uses an executable file-based installation program.
• The installation program was not designed for Windows Vista.
CAUSES:
Problems with executable file-based installation programs may occur if any one or more of the following conditions are true:
• The installation program is incompatible with Windows Vista.
• The driver is incompatible with Windows Vista.
• An issue occurs that is related to the user rights that are required to install the driver.
RESOLUTION:
To resolve this problem, run the driver installation program in compatibility mode. Or, use an account that has administrative credentials to run the driver installation program. You can also locate the .inf file for the driver, and then manually install the driver.
Important Before you use one of these methods, we recommend that you contact the device manufacturer or the driver manufacturer for more information about how to install the driver in Windows Vista.
To run the driver installation program in compatibility mode
Configure the driver installation program to run in Microsoft Windows XP Service Pack 2 compatibility mode. To do this, follow these steps:
1. Locate the executable file for the driver installation program.
2. Right-click the file and then click Properties.
3. In the PackageName Properties dialog box, click the Compatibility tab.
4. Click to select the Run this program in compatibility mode for check box, click Windows XP (Service Pack 2) in the Run this program in compatibility mode for list, and then click OK.
5. Double-click the executable file to start the installation program.
To run the driver installation program by using administrative credentials
Configure the driver installation program to run in the context of the Administrator account. To do this, follow these steps:
2. Right-click the file, and then click Run as administrator.
If you are prompted for an administrator password or confirmation, type your password or click Continue.
3. Follow the steps to install the driver.
To locate the .inf file and manually install the driver
Use Device Manager to install the driver. To do this, follow these steps.
Step 1: Locate the .inf file
Locate the .inf file that is included with the driver installation program. Generally, the .inf file is located in one of the following folders on the driver installation media:
• In the same folder as the Setup program.
• In a subfolder that is in the folder that contains the Setup program. Generally, the subfolder has a name such as Windows XP, Drivers, or WinXP.
If the driver files are packaged in a single executable file, you may be able to extract them or otherwise access them. To do this, use one of the following methods, as appropriate for your situation:
• Use a file compression program to extract the files.
If the driver files are packaged in a single executable file, you may be able to use a file compression tool such as WinZip or WinRAR to extract the contents of the driver package to a folder. The .inf file should be among the files that you extract.
• Use the Windows Compressed Folders feature to extract the files.
If you do not have the WinZip program or the WinRAR program, you may be able to extract the files by using the Windows Compressed Folders feature. To do this, change the file name extension from .exe to .zip. Then, use Windows Explorer to copy the files from the compressed folder.
• Extract the contents from the .cab file.
If there is no .inf file in the driver package, but there are one or more .cab files, you may be able to extract the contents of the .cab files.
Note This method is usually unsuccessful. Typically, these kinds of driver packages are created by using the InstallShield program. The InstallShield program uses a special .cab format that is not designed to be accessed by tools such as WinZip or WinRAR.
• Locate the files in the Temp folder.
If you still cannot access the installation files, try to locate extracted temporary files. Typically, files are extracted to a local Temp folder when you install a program. You may be able to view the contents of the driver package by examining the contents of the Temp folder. To do this, follow these steps:
1. Remove the contents of the Temp folder. By removing the contents of the Temp folder, you can more easily locate the temporary files that are created when you run the driver installation program. To remove the contents of the Temp folder, follow these steps:
a. Click Start and then click Computer.
b. Right-click the hard disk on which Windows Vista is installed, and then click Properties.
 In the Local Disk (DriveLetter) Properties dialog box, click the General tab, and then click Disk Cleanup.
 In the Disk Cleanup Options dialog box, click Files from all users on this computer.
 Under Files to delete, click to clear all the check boxes, click to select the Temporary files check box, and then click OK.
 When you are prompted to permanently delete the files, click Delete Files.
c. Use Windows Explorer to open the Temp folder. To do this, click Start
type %temp% in the Start Search box, and then press ENTER.
d. Start the driver installation program.
Note Some installation programs automatically delete the temporary files when the installation program exits. Therefore, leave the driver installation program running in the background.
e. Examine the contents of the Temp folder to locate the driver files.
Step 2: Manually install the driver
After you locate the .inf file for the driver that you want to install, manually install the new driver. To do this, follow these steps:
1. Click Start , right-click Computer, and then click Properties.
2. In the Tasks pane, click Device Manager.
3. In Device Manager, locate the device for which you want to install the driver.
Note To display hidden devices, click Show hidden devices on the View menu.
4. Right-click the device and then click Update Driver Software.
5. Click Browse my computer for driver software, click Let me pick from a list of device drivers on my computer, and then click Have Disk.
6. In the Install from Disk dialog box, click Browse, locate an .inf file for the device driver that you want to install, and then click Open.
7. Follow the steps in the Update Driver Software DeviceName dialog box to update the driver.
on May 10, 2010 | Computers & Internet
I keep getting this error message 1152 c:user/user'sname/appdata/local/temp/(location) when i tried to install a setup.exe program on window 7 ultimate. please help!
step1:
delete
Sep 20, 2011 | Microsoft Windows 7 Ultimate for PC
I am getting this error when trying to install anything on my win 7 ultimate. is there anything i can do to fix this? Says exactly this: "1152: Error...
Aug 11, 2011 | Computers & Internet
Yamaha ds-xg pci audio driver for windows 7
Follow this procedure to install:
  1. Download the drivers from the below link.
  2. Extract it to a temporary location.
  3. Open device manager.
  4. Rigcht click ont the device and select update driver.
  5. Then select, "Install from a specific location" and select the folder you have just extracted the downloaded driver.
  6. Finish installation
Now your Sound card will be working properly.
Download link:
http://www.4shared.com/file/nQINI5Yq/YAMAHA_DS-XG_PCI_Audio_CODEC__.html
Mar 02, 2011 | Computers & Internet
I am not able to install samsung NPS software. its showing 1152:Error extracting C:\Documents and Settings\Administrator\Local Settings\Temp New PC studio.msi to temporary location
I had faced this kind problem .the problem is downloading the Samsung usb driver and NPS with download accelarator.
do not use download accelerator !!! I think the problem is corrupt file
Nov 17, 2010 | Computers & Internet
Since I connected a Seagate Replica 500GB Hard Drive, I started receiving multiple Error 51 Events in my Windows Event log. They state: An error was detected on device \Device\Harddisk2\DR9 during a paging...
First, extract all data that you have on the hard-drive, while you still can.
Seagate's web-site suggests that you first download and run Seagate's "Drive Fitness Tool", which exercises the disk-drive, and produces a "fitness" report. If it fails, then delete all your "private" files, and either take the drive back to the retail location where you bought it, or get an RMA (Return Materials Authorization) from Seagate, to get permission from Seagate to return the drive to them, for them to analyze the disk, and probably replace it.
Sep 28, 2010 | Seagate 500GB REPLICA USB 20 16MB 25IN...
I am trting to install a mobile broadband device on my dell laptop - I get error 1152 erroe extracting to Temp location. The device will load fine on all other PC'S
Feb 12, 2009 | Computers & Internet
Error code 2329
It's a error message with Windows installer not for Itune.
Try to get latest windows installer from link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
Supported Operating Systems: Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows Server 2003; Windows XP; Windows XP Service Pack 1; Windows XP Service Pack 2
Dec 28, 2008 | Computers & Internet
Computers & Internet Logo
181 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
