Question about Jenn-Air JCB2280HES Side by Side Refrigerator
I have a very bad smell coming from the back of my refrigerator. The fridge itself is clean and there isn't any turned food inside. I can't figure out what's causing this awful smell.
  • 3 Answers
There is a pan built in under the unit that the water drains into when the defrost timer activates. the heat from the coils usually evaporates this water, but if the coils are filled with dust the air circulation is blocked and the pan will have stale water remain in the pan.the coils should be cleaned and the pan also. this can be done with a little help from an air compressor and paper towels
Posted on Jun 14, 2009
Why does my refrigerator smell so bad?
PUT A BOX OF BAKING SODA IN REFRIGE AND 1 INTO FREEZER ALSO. BUT TAKE EVERYTHING OUT, MAKE SURE NOTHING SPILLED AND IS UNDER A DRAW ROTTING. IF ALL IS CLEAN INSIDE, PULL OUT REFRIDGE IN BOTTOM BACK IS AN EVAPORATOR PAN FOR CONDENSATION, SOMETIMES SOMETHING CRAWLS UP INSIDE GETS TRAPPED AND DIES.
YUCKY BUT VERY REAL
Jan 05, 2015 | Kenmore Elite 78722 78729 Bottom Freezer...
Fridge smell and taste makes you sick, very clean and no food in it
Keep it open for a 4 or 5 hours... Then keep some cut lemon inside it.
Oct 27, 2012 | Hotpoint HSS25GFP Side by Side...
How to get rid of fish odor
Have you cleaned out the Freezer recently. We had the same issue with a rotten smell that we thought was from the fridge section, but found that it was actually from the freezer. Turns out it was just really old food.
Feb 17, 2012 | GE Refrigerators
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
We have a new side by side Samsung refridgerator and it has a bad odor. we have cleaned the whole thing out twice, moved ALL the food out and placed it in another fridge. the smell is still there.
I'm having the same problem, and have isolated the source of smell to be inside the deli drawer box... but I cannot figure out how to get the cover off the box. It comes out of fridge, disconnect the wire at back... but cannot open the "container" that the draw fits in.
Aug 25, 2010 | Samsung 26.0 Cu. Ft. Side-by-Side...
Bad smell from motor
You need to remove any spoiled food from the refrigerator and clean the interiors with hot water added with baking soda. You need to clean the door seals and remove the breaker strips. Also check for unusual wet insulation.
Hope this work
Jul 28, 2010 | Amana ABB1927DE Bottom Freezer...
Bad smell old food in unpluged refridge
The smell has permeated the plastic, set a fresh box of baking soda in the fridge. Give it a few days and clean it with awesome or murphys oil soap. You can also use comet cleanser but if to much rubbing will scratch the plastic.
Mar 21, 2009 | Refrigerators
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Bad smell coming from fridge
Is there any chance that small food particles have simply fallen into the fan and now trapped near or behind the fan ?
If this is the case, the food may be lodged in such a way that either heat given off from the fan or the fact the food may not be getting cool/frozen any longer, may have sent the food bad and is now generating the smell you describe.
I don't know of any fridge gas that smells like fish or funk as you put it, most are fairly neutral smelling or odorless to a point and certainly would not smell the way you have described.
  • Make sure the area is well ventilated ( run a pedestal fan nearby or open a window ), fridge gas can be harmful, even in small amounts ( especially if you don't know you're breathing it ), and if the smell is as bad as you say, you may very well be gasping for air.
  • Always have someone nearby when you attempt to do your own repair work of this nature, you just never know when you might need their assistance.
  • If you plan on looking into the problem yourself, firstly ensure the fridge is off, and unplugged before sticking fingers anywhere near a fan - plastic or not, i have seen 4 inch biscuit fan take the tip off an index finger of in a fraction of a second, so don't think for a minute because it's plastic, it won't bite.
  • Do not use any sharp pointed or metal objects to remove the fan or it's plastic cover, use fingers or flat blunt objects that can not puncture the lining of the fridge itself.
  • ( trust me when i say i speak from experience on this )
  • Be extra careful when removing the shroud around the fan, it should simply either click in or there maybe small coverings, covering 3-4 screws around the unit.
  • Remove the fan cover, being again extra careful of the unit itself and check around with a flashlight and perhaps even a magnifying glass.
  • If you can not find any offending objects, it is probably best to replace the fan and shroud and call the repair guy.
Feb 04, 2008 | Maytag MBB1956GES Bottom Freezer...
Jenn-Air JCB2280HES Side by Side Refrigerator Logo
312 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Jose Pino
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
