Question about Dorman 1994-1997 Honda Accord / Acura CL Front Right Window Regulator with
Start and dies
Just put timing belt starts and dies
    Sergeant:
  • 213 Answers
Make sure your timing set perfectly you maybe want to thaw which could damage your engine look for those little red dots on each gear and make sure they're all lined up perfectly
Posted on Aug 17, 2014
97 ford ranger 4cyl starts and immediately dies. Has some fuel pressure, but haven't put a pressure gauge on it
If it dies immediately when you remove the starting fluid the issue has to be with fuel delivery.
Mar 31, 2017 | Ford Ranger Cars & Trucks
Out of the blue . truck looses power and wants to die. not letting it die by hitting gas peddle it runs but starts back firering supper bad. truck dies .starting up it doesnt want to put . made it home .....
if you have replaced cap and rotor plus coil and it seemed to fire up then i would take the next step. For sure put your new plugs and wires on then make sure you have replaced your air filter, and change out your fuel filter, fire up the vehicle if it doesn't start I would suggest changing the fuel pump. If it starts up make sure you put in some BK fuel injector cleaner in your fuel it might be you have dirty injectors. If all fails then get back with me and we will look else where. Good luck hope this info helps you out
Jul 05, 2014 | 1999 Chevrolet Silverado 1500
The car starts but dies as soon as you put your foot on the accelerater and then won't start again. The battery is fine and it's not the timing belt any suggestions please?
Sound like fuel problem,Vehicle needs a set amount of pressure to spay out of the injectors,this atomization ensure proper comustion,If it was MAF(mass air flow) obviously you would be able to restart,but would complain about hesitation,When you step on the gas you apply a load on the engine and a good working fuel pump ensure it meets that load3_17_2012_7_10_37_pm.jpg
Mar 17, 2012 | Cars & Trucks
I put timi belt and sparkplug on 2005 Kia amanti and ran for 5 min started runnig roughy it to coils put to new coils on it it ran 5minute and died now it won't start
Check the timing. Before I put anything back together I always start the car and make sure everything is okay. After puting the belt on you always want to rotate the crank two full revolutions to double check your timing. This is of course assuming u did the timing belt because of maintenance and not because it broke.
Dec 24, 2011 | 2005 Kia Amanti
Car sometimes starts hard like 1 out of every 5 starts and runs rough most times may even die out acts like a miss dies every time it is put in gear unless u foot brake it every so often you start it and...
try putting some injector cleaner into the gasoline tank because sometimes your fuel injectors do get clogged up and needs to be cleaned to allow the lower 87 octane through the injectors. Some of the times that the timing belt has been changed and misses with the timing with the piston heads and valves which opens and shuts while the gasoline fuel is being put into the piston heads chambers so if your timing is off would cause this similar problem as well.
Jun 04, 2011 | Chevrolet Caprice Cars & Trucks
Dorman 1994-1997 Honda Accord / Acura CL Front Right Window Regulator with Logo
81 people viewed this question
Top Dorman Home Experts
Donni Steen
Tom Chichester
Are you a Dorman Home Expert? Answer questions, earn points and help others
