Question about Asrock 775VM800 Motherboard
Error code 0x00041287
Bsod after post screen
Tip
Blue Screen Of Death (BSOD) Important Info When you get a Blue Screen Of Death...
When you get a Blue Screen Of Death (BSOD) on your computer this can be very frustrating. Below is the info you need to get from a BSOD because the way that Microsoft words the message a lot of people miss the real important parts. With the right information this will helps tech support help you address your problem quickly.
The first thing to look at is the error message. A lot of times you will get a message like the one below that states "PAGE_FAULT_IN_NONPAGED_AREA". In the case of this BSOD the error screen the error code is a generic one of 0x00000050 so we have to rely on message that tells us that the problem was with the memory or the page file.
The next thing to look at is the error code. Note you really do not need the info between the parentheses for standard trouble shooting.
So with both pieces info this will help tech support figure out where the issue is at and where to troubleshoot.
Note the file name that the BSOD list normally is not important in troubleshooting the in most cases it just point to the point where Windows had the problem.
on Mar 29, 2010 | Computers & Internet
My aspire 5520-5156 doesnt boot. Please help
try to hit pause/break key on bsod to get the error code so that you can check the error, take down the name of the file that is last on that list in the video. It may be software related but you could also have a bad harddrive depending on what the blue screen error code tells you. BSOD Errors are something like this: 0x000000
Oct 25, 2013 | Computers & Internet
Blue screen frequently appears, and it reboot by itself? pavillion g7-1070us
A blue screen often called Blue Screen Of Death, BSOD, indicates that something is wrong with the computer. Usually it is a driver that is not correct or corrupt.
You need to specifically identify that the BSOD message is. If the system reboots before you can read it, boot the system while hitting F8 many times per second until you see a black and white screen with a number of options. Towards the bottom will be one regarding automatic restart on error. Uncheck that option. Now the BSOD will stay on the screen and you can post the stop code here to get help.
I hope this helps. I do this for fun & feedback not $$$
Jim
Oct 05, 2011 | HP Pavilion dv9000z Notebook
BSOD error. Bug Check String : IRQL_NOT_LESS_OR_EQUAL file ntkrnlpa. Please Help
if u are able to logon to the windows means next time post the brief error code also use free tool blue screen view to view the dump files and post me i will solve you
Mar 02, 2011 | Computers & Internet
How do i fix my computer with a blue screen that keeps shutting it off?
Blue screen errors, or blue screen of death (BSOD) errors, are the most severe errors Windows can encounter. Since Windows can not recover from this kernel level error, a blue screen is displayed with the error details. The error details contain a STOP error code, which indicates the type of error.
There are a lot of possible causes for blue screen errors, but most of them relate to the computer hardware. The cause of a BSOD error can be a temperature problem, a timing error, a resource conflict, hardware failure, a corrupt registry, a virus or simply a device incompatibility or driver error.
Post your OS please!
Oct 01, 2010 | Computers & Internet
I have blue screen problem
You need to enter in safe mode then apply the BSOD Reg Fix on Restart then reboot this will allow you to see the error open notepad and copy these lines of code into a fixbsod.cmd file then run it in safe mode.
Windows Registry Editor Version 5.00
;Disable Automatic Restart in the event of a BSOD
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CrashControl]
"AutoReboot"=dword:00000000
when you know what the error is post a comment HERE
Aug 19, 2010 | Microsoft Windows XP Professional for PC
Windows xp tries to start in safe mode screen then as program starts gets brief blue screen then back to safe mode start selection screen once again this keeps repeating
your system will do this as it has shut itself down to protect itself, to make the blue screen stay on so you can write down the error code (e.g stop 0x0000007B),you need to choose the option of `disable automatic restart on sytem failure` (this will be on safe mode screen, reboot, then when you get the B.S.O.D it will stay on and display an error code, google it and you get the answer or post the code on here and i`ll tell you
Jan 14, 2010 | Dell Latitude D800 Notebook
Blue screen and the charger works sometimes
blue screen aka bsod. when you get this bsod it will show you stop error code. you need to get the code to identify the exact issue you're having. If the bsod occures after the dell logo issue might be the video card or memory. if the bsod occures after windows logo then if might be caused by a corrupted windows updates or windows system file corruption. if the bsod occured after dell logo then check your memory if you have 2 ram modules try to remove 1 ram first then try booting your system using only 1 ram, try to swap and isolate reseat and teach eash slot on each ram module. if bsod occures after windows logo then try to run a test for your hard drive Fn+Power. If no errors it might be windows file corruption which needs to be restored or re-installing OS.
Oct 02, 2009 | Dell Latitude D510 Notebook
Bsod problem due to reliance lxu 800 usb modem drivers
Hello dear, I'm one of the users of LXU 800 modem. I tried all the sources and found there is no way resolving this issue because the manufacturer has not yet released any updates till now. I also heard the team at Reliance doesn't care about this issue because the actual manufacturer is LG. Anything to share? Meet me at 3hackerdude3@gmail.com. Have a great day. Yours truly, N Bhargav Reddy.
Aug 15, 2009 | Computers & Internet
Asrock 775VM800 Motherboard Logo
32 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
pankaj rautela
pankaj rautela
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
