Physi-Cal Enterprises MIO Sport Motiva Series M9W-32P3C8L3 Heart Rate Watch Logo
A
Anonymous Posted on Mar 23, 2014
Set time Can't remember how to set the time.
Every time i set clock, it goes back to all zeros. Why
When You set clock push clock, then after you set time push the clock button again! But remember this, if You unplug the Microwave most of the time it will lose time and You will have to reset it! Hope this helps!
Locked out o device do not know pasword
If you set a pass code (or pattern) that you cannot remember, please enter the wrong password (10-20 times) until you are prompted to sign in via your google account. Please note, this will only work if you have already setup your google account on the tablet. If you have not set up a Google (or Gmail) account on the tablet, you will have to perform a firmware install, which will revert the tablet back to factory settings.
Support Troubleshooting Guide
Set timing 383 dodge 1969 superbee
Set timing at 650 RPM in Nuetral, if it is a manual transmission set to 0/TDC, if automatic set to 5 degrees BTDC, ignition points should be set at .017" with a quality feeler gauge and final dwell is 33 degrees, remember correct point gap is essential to get the timing correct. If you experience "PING" ****** timing 2 degrees.
5helpful
I cannot get my ihome ip11 model out of military time. Help. Thanks for any help you can give
Hello pac31:
For 12 hour time format setting: Press the Alarm Ser Button durin time setting to set 12-hour 24-hour display format. Remember to set the correct AM or PM time (an icon to the right of the time display is the PM indicator ther is no AM indicator).
Remember to click the thumbs up if this helps.
Sincerely, Peter
I replaced my head gaskets on a 85 ford ranger 2.8 v6. When removing my distributor I neglected to mark it.. Now my timing is off. How do I solve this??!
Turn your motor by hand to bring up TDC #1 fire. Set your distributor in place. Remember it will turn with the direction of the cam gear approx 1/2 post when it seats so you need to compensate for this. Set your cap on and follow down #1 post and mark your housing. Remove cap and turn dist until rotor centers on mark. Start and time (remember to remove timing plug) with timing light. Did you remember to use new head bolts?
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
I want to correct the time. My time is just way off and I want to set the clock to correct time.
To change the time double click on the bottom right corner of your desktop where the clock is.
Then, on the dialog that opens set the time. Remember to also set the timezone so that the time will be set according to your location.
1helpful
I cannot set preprogramming on my vcr to the tv.
Have you set up the VCR on initial installation correctly!!
Remember correct date, day and time am/pm must be set firstly before any timed recordings can be done properly.
Top Physi-Cal Enterprises Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you a Physi-Cal Enterprises Exercise and Fitnes Expert? Answer questions, earn points and help others
