Question about LG LFX25960ST Stainless Steel French Door Refrigerator
How do i replace the water line on a lg refridgerator
How do i change mju62070602
How to replace water filter Housing?
most of the time when you get a filter it has its own housing and they are and in the water line filter, just unscrew the water line and replace, just make sure the arrow is going in the right direction
Dec 02, 2015 | Samsung RF267AB (25.5 cu. ft.)...
Saddle valve on water line to refridgerator won't shut water off
If you can not shut the valve off then most likely it has calcium build up in it. I would recommend shutting off the water supply at the angle stop. Then removing the saddle valve and see what is going on. If it is built up with calcium you may be able to clean it depending on how shot it is. If you are unable to clean it then a new one is not that expensive and they are easy enough to replace
Jun 05, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Water and ice have a funny taste
Try flushing out with bi carbonate of soda.
May 17, 2010 | KitchenAid KSRS25ILSS Side by Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
Door display shows eror code FF
This means your freezer fan is not working and you'll need to replace it. It's one or two small plastics fan that sits behind your freezer drawer. It's located behind one of the two wall panels behind your freezer drawer. They circulate the air flow throughout, one for your refridgerator and the other for freezer. I had to have both replaced and now my line holder in the bottom back right side of my refrigerator is leaking, so I had to shut off my water until we find the part number. Good Luck! I know I'll need it because my wife has all LG in the kitchen including a flat T.V and 2 microwaves.
William,
Aug 05, 2009 | LG LFX25960ST Stainless Steel French Door...
LG model GR-620RW leaking water inside at back top
the drain hole (freezer) is blocked,
Apr 08, 2009 | LG Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
