Question about Wilton Cake Turntable, Trim n Turn Ultra, 1 turntable
Wilton trim n turn cake turnable
It no longer turns. Can it be fixed?
Where can i obtain the cake decorating directions for a wilton teenage mutant ninja cake pan?
Dear Dennis,
I found a site for you to look at to get cake decorating directions for Wilton TMNT's cake pan.
Go to: slice-heaven.com
and in the search box, type: teenage mutant ninja turtles
then look over and choose your option.
I found other sites but none as cheap or easy.
May 02, 2017 | Baking
How long to bake Wilton easy bake for a layer cake. Four layers are one cup capacity each
Check after 30 minutes. Insert a metal knitting needle or a small skewer and it should come out clean with no batter.
I you COMMENT below with the make of your breadmaker, I might be able to supply you with the instructions.
Jun 27, 2016 | Kitchen Appliances - Others
I need instructions to put Wilton's 3 tier party stand together
According to Wilton:
You should have 8" plate, 10" plate and 12" plate
Match the sizes with rings and legs on table.
Attach legs to serving rings,twist threaded end securely into housing on each serving ring. Tighten using wrench.
Attach 8 1/4 Serving ring to Center Footed Base Ring -Position serving ring with footed leg out. Line up the other 2 legs with the correct housing on the base ring, the width between housing should be same as that between legs.. Insert end of legs into housing.
Next attach 10 1/4 Serving ring to Base Ring, You will need to move clockwise around base ring to attach this ring. line up legs and insert legs and tighten.
Attach 12 1/4 serving ring to base ring. Insert legs into last pair of housing on the base ring.
Position plates so lip edge rests inside serving ring.
Apr 16, 2013 | Wilton WHITE 3-TIER CUPCAKE STAND...
Where can I get a cookie press? My old one just broke after 25 years of using it.
If you are looking for a very simple cookie press, you could try amazon; http://www.amazon.com/Wilton-Cookie-Pro-Ultra-Press/dp/B000I4OJ1E/ref=pd_sim_k_1
But if you want to replace your broken one with something a bit sturdier, take a look at this link:
http://www.wilton.com/store/site/product.cfm?sku=2104-4018
Feb 28, 2013 | Baking
Anyone have a good recipe for a basic yellow cake?
This is the recipe that I use. It's very simple and always works.
http://www.wilton.com/recipe/Basic-Yellow-Cake
Microwave the plate not turning
remove power. turn it upside down. remove access cover and determine if there is a mechanical obstruction...could even be belt driven with a broken belt.
Oct 19, 2007 | Microwave Ovens
Wilton Cake Turntable, Trim n Turn Ultra, 1 turntable Logo
23 people viewed this question
Top Wilton Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Wilton Audio Player and Recorder Expert? Answer questions, earn points and help others
