Question about Alpine INE-W940 6.1-Inch Audio/Video/Navigation Receiver
Settings icon not lighting up
Cant get into settings to do anything
My sound isnt working. What do i do?
Hi click on tools or settings icon should open a page with all the settings look for SOUND Click it on & check the settings volume adjustments. .good luck
Jul 18, 2016 | Tablets & eReaders
Why has my Kindle stopped working?Kindle working fine; suddenly message came on and Kindle went blank; light is still on; when I try to shut off/back on it starts up and swipe to unlock works and nothing....
make sure its charged and then hold down the start button for 30 seconds and see if this will set the Kindle to work. If that doesn't work call customer service
Feb 04, 2015 | Amazon Kindle Paperwhite 3G
Unable to turn on the sound on my Asus tablet T300. What do I do ?
The sound icon with a slash means the mute is turned on. Tap on the icon to see is there is sound otherwise you have to go into settings and manually turn on the sound.
Jun 12, 2012 | Tablets & eReaders
I can login but cant find anything on my yahoo messenger page........its blank cant see anyone......
Right click on the YM icon on your system tray, beside your clock, and select Exit. Restart and you should be all set.
LMK if it this will not work.
Oct 31, 2009 | Yahoo Messenger
I can not change the sounf volume
Start-settings-control panel-sound.
Jul 09, 2009 | Compaq Armada E500 Notebook
All main menu icons dissapeared while installing an app from cydi
I would do a full reset on the iphone which you can get to by going to the settings and scroll to the bottom and it should give you a reset option this will delete everything but assuming you make a backup whilst in itunes you should be able to re synch it as far as contacts and anything else you want from your itunes afterwards.
Jun 28, 2009 | Apple iPhone Smartphone
Speakers are hooked up, cant listen to anything.
ok the first thing u have to check in ur windows xp desktop that the volume icon is diplaying in the bar below the screen .if not than go to controlpanel --> sound and audio devices --> place volume icon in the taskbar check this option and the volume icon will be avaliable on ur desktop.remember this option is only avaliable if the drivers is installed . than u can double click this icon and set the equilizer. if ur sound not installed than u have to install it from the motherboard cd that is provided by the manufacturer. thankx and take care of urself.
Jun 09, 2009 | Foxconn 45CMX socket LGA775 motherboard...
My Ipod touch used to let me on anything on the internet but now, it says that the wifi is connected but i cant load anything on the internet. for example, when i try to get on youtube it says "you cannot...
Select "Settings" and then "Wi-Fi."  Verify that the Wi-Fi is switched to the "On" position.  Also, verify that you are not connected to a "closed" connection (indicated by a lock icon next to the connection icon).
Mar 01, 2009 | Apple iPod touch
Alpine INE-W940 6.1-Inch Audio/Video/Navigation Receiver Logo
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
