Question about Maytag Bravos 4.5 Cu. Ft. Washer
Whats a code 06 on model 110.44936203
Stops during cycle
Why would a whirlpool duet sport model number WFW8300SW05 starts fine stops during cycle. No error codes door locked red light on water in machine.
you have a plugged or partial plugged drain pump for sure. maybe there is a 20 stuck in it this time! easy to find just follow the drain hose back and you will find your pump.
also could be the cycle your using has a bad area in timing cct. check a different cycle like the delicate cycle and that will confirm pump or cycle
Jun 10, 2014 | Washing Machines
Kenmore elite he3 model 110 f-06 code comes on and washer stops .
I was getting a F-xx code can not remember the number.
If you remove the bottom front plate , I remember 3 three screws.Behind that is the filter for the machine, mine had a 2-3" white cap that came off with a screen inside that was plugged. When you open it up you can get a fair amount of water come out. The machine will not work until you put the front cover back on.
UNPLUG the machine FIRTS
Aug 23, 2012 | Kenmore Washing Machines
Why does the washer stop during a load and "F 06"
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code
GENE
Sep 09, 2011 | Kenmore HE2 Plus Front Load Washer
My Kenmore Elite Calypso Model #110.24086200 SN #CR3808384 is not completing it's cycle and error code (06) shows up. What does code (06) mean?
Error codes start on page 46 and detailed instrustions to run diagnostics start on page 47.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2c1e295a88aaaae885256c5d004632a4/$FILE/8178010.pdf
Mar 20, 2011 | Kenmore Washing Machines
My top loading machine will not complete an entire cycle - it stops during the rinse cycle - so I have 1/2" of water in the bottom of my machine - Fisher and Paykel
Hi just read your posting.Now what I need to know is the model number of your machine which can be located on the back on a sticker.Also when it stops in the rinse cycle does an error code appear in you LCD screen if you have that model or do a series of lights come on and in both models it beeps.Now if you have the model where the lights come on they will be in a row of 8.Starting from the left to right what lights have turned on when it stops in the rinse cycle Is it the 2nd and 5th or the 3rd and 8th --etc-?Please reply with this additional information and I can help you rectify this fault for you.
Jun 22, 2010 | Washing Machines
Whirlpool WF665/1 clunking/grinding
Could be worn drum bearings.
Jun 04, 2010 | Washing Machines
Washer stopping and flashing F 06 fault
F/06 ---- ERROR IS FOR ----------- Drive Motor Tachometer ErrorThe control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.----------
AND TO SOLVE THIS ---------Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU) --
Check the Drive Motor
Check the MCU
Check the Wire Harness
Apr 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Help! Mt Kenmore Elite Quietpak2 HE3 keeps
F/06 Drive Motor Tachometer Error
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Maytag Bravos 4.5 Cu. Ft. Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
