Question about Sakar Cyber Gear Slide Click Text Messenger
How do you set up monster high texters
How do you set up the texters, such as putting in the time,date,year an getting them ready for use
How do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
I have a clock that will not get correct time. I have no way yo set it . Model #44100 Equity.
All Equity Insta-Set clocks automatically set the correct time and date when you turn on the power. Occasionally, the automatic time-setting feature malfunctions and you must reset the time yourself. Manually changing the time to the correct time on an Equity Insta-Set clock requires the push of only a few buttons to get the clock back on track:
1. Press and hold the "Alarm Set" button for five to seven seconds, the year will begin to blink when the clock is ready for adjustment.
2. Set the year by pressing the right-arrow, "Up" or "+" button, depending on your model of clock
3. Set the month, day, hour and minute. Press the "Alarm Set" button to cycle through each field, and use the "Up," "+" or right-arrow button to adjust the values within each field.
4. Press the "Alarm Set" button after setting the date and time to store the information into your clock's memory.
Best regards,
gylacz
Mar 18, 2011 | Audio Players & Recorders
How to set date and time
Set the date and time:
The current date and time are shown in the display when the machine is on and ready for use (Ready mode). The date and time will be printed on all faxes you send.
1. Press Menu.
2. Press Left Right Arrow to choose SET DATE & TIME and press Start/Enter.
3. Press Start/Enter when the display shows Date Format.
4. Press Left Right Arrow to select either Europe (day month year) or USA (month day year) and press Start/Enter.
5. Press Start/Enter when the display shows Date & Time.
6. Set the date and time. You can move the cursor by pressing Left Right Arrow.
7. Press Start/Enter when the date and time are correct.
1-AM 2-PM will display.
8. Press 1 or 2.
Dec 07, 2010 | HP 1050 Plain Paper Inkjet Fax
Date/time setting
All digital camera have the date and time setting, and they often have a daylight time setting so you can just switch that on and off at the appropriate time s of the year. Some will let you put the date and time on the fac of the picture too, by this is very dependent upon the make and model of the camera.
Nov 18, 2009 | Cameras
Need to reset date and time after changing the
Here's the instructions on how to do that :
Quick Instructions on Setting the Date/Time:
    Note: The unit will revert back to normal display if no other key is pressed for 10 seconds.
The manual for this device can be found here :
http://images.cableorganizer.com/dymo-label-printer/DateMark_Time-Manual.pdf
Oct 26, 2009 | Dymo DateMark Date/Time Stamper
How reset time?
You can set the date and time from the control panel. When a fax is transmitted, the
current date and time are printed along with the fax header. The date and time format
is based on the language and country/region setting.
Note If your HP all-in-one loses power, you will need to reset the date and time.
1 Press Setup.
2 Press 4, and then press 1.
This selects Basic Fax Setup and then selects Date and Time.
3 Enter the month, day, and year by pressing the appropriate numbers on the
keypad. Depending on your country/region setting, you might enter the date in a
different order.
The underline cursor is presented initially beneath the first digit; it automatically
advances to the next digit when you press a button. The time prompt
automatically appears after you enter the last digit of the date.
4 Enter the hours and minutes.
5 If your time is displayed in the 12-hour format, press 1 for AM, or 2 for PM.
The new date and time settings appear on the control panel display.
Regards...
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to set time and date on 91 seville
Below the information center locate the small hole right of the words date/time set.Insert a pen or pointed object into the hole. The function will flash when it is ready to set. Use the time/temp and the range buttons to adjust. The first push of the pen the minutes will flash . second the hours, third the date, fourth the month, fifth the year and sixth will end time date set function. Any other buttons will end time date set except time/temp and range buttons.
May 11, 2009 | 1991 Cadillac Seville
Ho w to set the date and time
Go to the link below. You need adobe acrobat to read. THere is a section in the manual called "Adjust Date & Time"
For Date:
Put Calculator on RATE SET
Press Time/date key: enter the date using a decimal between the month, day and year (all 4 digits) please the date/time button. It should reset. (Exmple: 01.16.2009)
For time:
Leave Calculator on RATE SET
Press Time/Date key until time shows up. just like date, press the hour then the decimal then the minute. (Example if the time is 10:15 you enter 10 . 15) Press the Time/Date Key and the time is set.
This link is the manual:
http://www.sharpusa.com/files/cal_man_EL1750PIII.pdf
Jun 04, 2008 | Sharp EL-1750PIII Calculator
Time
This should take care of it for you.
NOTE: The current date and time are displayed on the LCD when the machine is ON and ready for use (Standby mode). The date and time are printed on all faxes that are sent. When the machine is installed for the first time, the LCD will prompt for the date and time to be set.
  1. Press the [Setup] button on the Control Panel. 'Fax Number / Name' will be displayed on the LCD.
  2. Press the left or right arrow button until 'Time / Date Setup' is displayed, then press the [Start / Enter] button to access the Time / Date Setup menu. The LCD will prompt you to select a Date Format.
  3. Press the [Start / Enter] button.
  4. Press the left or right arrow button to select the required date format, then press [Start / Enter]. The LCD will display the currently set date and time using the selected date format and prompt to set the month. The cursor will be under the first digit of the month and the number will blink.
    NOTE: If you select USA, the date will be displayed in the format of Month-Day-Year. If you select Europe, the date will be displayed in the format of Day-Month-Year.
  5. Enter the correct date using the numeric keypad on the Control Panel. Each time you enter the appropriate number, the LCD will prompt for the next item to be entered in the following order: month, day, year, hour, and minute.
  6. Enter the correct time in 24-hour format using the numeric keypad. For example, enter 22:30 for 10:30 P.M. If an invalid number is entered, the LCD will not proceed to the next step. Re-enter the correct number.
  7. Press the [Start / Enter] button to save the setting and return to the Standby mode. The LCD will display the date and that has been set.
Dec 13, 2007 | Office Equipment & Supplies
Reset time
Nov 05, 2007 | Dymo DateMark Date/Time Stamper
Sakar Cyber Gear Slide Click Text Messenger Logo
89 people viewed this question
Top Sakar Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sakar Toy Expert? Answer questions, earn points and help others
