Question about Amigo Rd 3 Wheel Scooter with 33AH Battery Pack
Flat battery scotter does not move even with charger on it
  • 53 Answers
The scooter will not move when plugged in, if you have a free wheel lever on the back to allow the scooter to be pushed make sure the lever is in the run position also have the batteries load tested
Posted on Mar 16, 2015
If the batteries needed changing would the green charging light still come on and would the alarm beep when attached to scooter and turned on?
Yup. The alarm beeps if you have the charger plugged in and turn on the key even if the battery is flat. The charger won't bring a totally discharged battery up to full charge. You can charge the battery individually using an automotive style battery charger. The charger should NOT be the automatic type. It may take some time to recover a flat battery. Charge it until you can see at least 10 volts on the battery. The scooter charger can then finish up the charge. If after you go through all this and the batteries will not take a charge, then it's battery time.
Nov 20, 2015 | Health & Beauty
Makita DC1804T charger
No, batteries age even if not being used.
Mar 28, 2014 | Makita Univ Volt Charger
Battery not charging fully go go elite scotter
hi, And you're sure the charger's okay ? , check the fuse located within the battery pack ...
Regards
Rob
www.gewizrepairs.co.uk
Nov 24, 2013 | Pride Mobility Products Go-Go Elite...
Charger cs1212su not working
could be several problems. most common is bad plug if there is any damage at the plug have it replaced. next is the harness where the charger connects to the batteries possible bad connection last is charger failed. you may need to contact amigo for a service location in your area 1-800-my-amigo
Oct 29, 2012 | Amigo TRAVELMATE Mobility Scooter ()
Scotter will lock after running 10 feet
Check the batteries, charger, state of battery charge. Have the batteries load tested. Replace the batteries if over 2 years old and they load test bad
Aug 05, 2012 | Pride Value Line Revo Scooter 3 Wheel
Plugged in to charge battery, red light flashing, no green light on, charged all night still flat, what could be the problem.
Hi. Sounds like there is no connection between the charger and the batteries. The charger uses the voltage in the batteries to regulate the charge. If the charger is not connected then the charger will not operate at all.
The fault can be a broken wire in the charger plug, or faulty charger socket on the scooter. Can be caused by faulty battery connectors, or wiring from the charger socket to the batteries.
Try moving the charger plug in the socket while the charger is operating. These sockets sometimes wear and dont contact properly.
The best way is get someone with a multi-meter and try and trace the fault for you.
Good luck. Neil.
May 28, 2010 | Pride Mobility Products Hurricane PMV...
Boreem Jia Scotter - Model ID and manual?
how do i change the battery on my boreem jia series electric scooter
Aug 23, 2009 | Cycling
Batteries are charged, scooter won't move, no power to display
It is impossible to overcharge with the Pride charger. When the battery is full, it will stop charging and check about oncew a miute to maintain the charge.
Now, when you plug in the key (looks like an audio headset jack) does the battery meter indicate a full charge? Also, the scooter will not move if its in free wheel mode, and it will not move if the charger is plugged in. Beyond these first steps, you will need a voltage meter to troubleshoot.
Jan 18, 2009 | Pride Mobility Products Go-Go Elite...
Amigo Rd 3 Wheel Scooter with 33AH Battery Pack Logo
74 people viewed this question
Top Amigo Health & Beauty Experts
James Rose
Level 1 Expert
Tom Chichester
Are you an Amigo Health and Beauty Expert? Answer questions, earn points and help others
