Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool F-25 washer does not spin
  • Whirlpool Master
  • 5,323 Answers
No spin, or lite spin try these:
Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically.
Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand.
Or try the hand test:
If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING:This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a bloody death. Proceed at your own risk! Have a nice day.
- put the timer on a spin cycle and open the lid- grab the inner basket with maybe 30% to 40% of your hand strength with your left hand
- turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin
- if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand
- if it takes very little force to stop the tub from spinning, the clutch needs to be replaced.
Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either)
Next check for a loose, worn or broken belt if belt driven. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle.
On some front load models u may need to check the STATOR assembly.
The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand.
Your next step is toremove the cabinetand jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem isnot in the gearcase- look for trouble in theclutch,basket driveor the tub drive block
If, on the other hand, the disc is NOT spinning, check for a problem withthe motor drive coupleror one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer.
Read more:Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washerhttp://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiNBy the way my advice is free cuz God is good!
Posted on May 12, 2015
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Whirlpool design 2000 is imbalanced eery load - moves around violently, makes pounding noises.
Thanks for choosing FixYa and welcome. You need to check the suspension of the washer and make sure everything is intact. Now, if the washer is thumping during spinning, this is probably the motor drive or the spin bearing. This would cause a lot of noise. Your washer will act up if it is not balanced right. Check the floor and make sure it is level. If that checks out, look into the motor drive and bearings. The motor drive controls the spinning.
Apr 28, 2011 | Whirlpool Washing Machines
My whirlpool direct drive washer will not spin. the motor turns,it fills up,and it drains .it was loaded too heavy with towels and will not agitate or spin the mdel is whirlpool lxr9200hq1
The coupling needs to be replaced, it has broken in two pieces and cannot transfer power from the transmission. That part is around 25 bucks if you have a local appliance store, sears usually has to order them. But appliance repair shops usually keep them on hand, it's a common part..
Jan 05, 2011 | Whirlpool Washer Motor Coupling 285753A
My macine draines the water but dont want to turn over to spin, what can the problem be?
soundsw like you have a bad clutch on your unit costs about 25 dollars problem is you would have to know how to remove and then reinstallthe entire transmission to replace the clutch heres some instructions on how to get the job done fixitnow.com/.../how-to-replace-the-clutch-in-a-whirlpool-direct-drive-top-loading-washer
hope this helps any problems write me back
Jul 14, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Why wont my washer spin?
You need to replace the drive coupler. It is the piece that is between the motor and the transmission. You can see this part when you tilt the washer back and lay under it and look between the motor and the tranny. This is a very cheap part only about 25 bucks.
Jan 30, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle problem
hi this is the part you need to replace motor drive coupling located on the motor and the transmission. replace this part $25.oo thanks the appliance doc
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer not spinning
Sounds like the brake liner could be broken. When the machine starts to spin, the motor turns in the opposite direction to the wash cycle and causes the bowl to lift off the brake liner and the bowl then spins freely. Either the riser cam is worn/broken or the brake liner is broken. This is quite involved and you may have to call in a tech.
Nov 03, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
96 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
