Question about Ovens
Jgsp23bey5bb oven does not turn on
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Jun 03, 2015 | Moffat Ovens
Why is ignition still working after oven is lit
Oven Control Board
Relay board:
May 10, 2015 | Ovens
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 | Ovens
After cleaning the control panel ribbon, the oven will not shut down (top and bottom ovens. Is this the thermal oven shutdown fuse that needs to be replaced? If so, how do I remove the fuse from a W
Oven Control Board
Relay board:
Dec 28, 2014 | Whirlpool Ovens
Element heats up when we only put oven light on
Oven Control Board
Relay board:
Nov 17, 2014 | Whirlpool RMC305PV 30" Built-in Microwave...
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
Jul 28, 2014 | Whirlpool Ovens
Oven will not shut off just keeps getting hotter
Oven Control Board
Relay board:
May 21, 2014 | Whirlpool WOS51EC0AW 30" Single Electric...
DCS Double oven cooling fan will not turn off
Is this a convection oven? Need more info.
Mar 03, 2014 | DCS (WOTD-227) Double Oven
Whirlpool gold electric oven code pf and broiler won't turn off, oven goes into clean mode when baking
Oven Control Board
Relay board:
Dec 22, 2013 | Whirlpool RBS275PD Electric Single Oven
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 | GE Ovens
Ovens Logo
13 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
