Question about GE Monogram ZDI15C Automatic Icemaker
No water coming through water dispenser
Icemaker working fine
tech master
  • 120 Answers
SOURCE: Water dispenser not working
2 things i want you to try before you call a tech out first under frezer door there is a connector where the 2 lines connect disconect both off now actuate the water at door if you get water out the line that means your line inside door is frozen 2 if you don't get water that means your water reservour is frozen so to solve problem cheapest way is to derost it by unpluging it for maybe 2 days and if it was frozen it should go back to normal and this time keep your temps in right settings refrigerator section at 37% and freezer from 0 to 4 % at all times that will keep lines from freezing
Posted on Oct 12, 2008
HVACRH20
  • 237 Answers
SOURCE: Got ice but no water
It could be the water valve side for the dispenser. So a coupleproblems can be had with this description. 1. The electricsolenoid for the valve is bad so it doesn't open the valve. 2.The valve itself could be bad so the solenoid opens it but nothingflows. 3. The water line could be frozen inside the door so nowater flows. 4. The dispensor switch is bad or the plastic holderthat holds the switch is bad so the switch fell out of its properposition. 5. The circuit board is bad.
Easy way to check is to pull out the fridge and take the water line offthat valve by pressing down on the little ring around the line whilepulling up on the line (tube thing). It should pull out easily(to reinsert just push the tubing back in without holding the littlering down, it goes in by itself and self-seals). With the tubeout of the solenoid valve have someone operate the water dispensorlever and see if water shoots in your face ha ha. Read further ifyou're testing by yourself...
You can also do the same test from the front underside where the tubinghas a coupling just under the door hinge area (so you can take the dooroff without cutting the tubing). Pull the lower skirt off the front ofthe refer and you should see the tubing and little coupling, it worksthe same, push down on the ring area and pull the tubing out. That way you don't have to move the fridge and can operate thedispensor lever yourself to see if water flows out the disconnectedcoupling. If water flows then the valve/switch/circuit board areworking fine of course and your tubing is frozen at the door. You willneed to defrost the tubing somehow, usually means a hairdryer blowingup into the dispensor area or turning off the whole refer and leavingthe door open for a day.
If nothing happens (no water still) then you need to check if thesolenoid is working electrically. Pull the fridge out and pullthe wire plug off the icemaker valve and put the wire plug from thedispensor valve on the icemaker valve. Watch inside the icemaker andpush the door dispensor lever, if water flows into the icemaker thenthe electrical door switch/circuit board is OK and the problem islikely the solenoid valve to the dispensor is bad or a frozen line inthe door still. You get the idea, you can swap wires/valves andeven tubing (if their the same size) around till you logically find thepart not working. Remember in troubleshooting you're not reallytrying to find the broken part... you're trying to find ALL the otherparts are working, which by process of elimination will lead you to thelast part that ISN'T working.
If you are comfortable with electrical troubleshooting using amultimeter you can check for 110 vac at the plugs when the switch ispress also but that depends on your tools and skill level, etc.
See this link for a diagram of that door assy and the parts involved.
Typically I'd be suspicious of the valve itself being bad or thecircuit board, next on the list is the switch, and last would be thefrozen line.
Good luck and let me know what you end up finding!
If nothing happens then you are down to either the circuit board is bad or the switch is bad.
http://tinyurl.com/5upeab
Posted on Dec 15, 2008
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
Posted on Dec 19, 2008
SOURCE: Icemaker works fine, only dispenses water
make sure that the ice shoot is not clogged up with ice or the in the ice basket where the ice goes through. Sometimes the ice can be stuck together and jam and nothing will come out.
Posted on Jan 08, 2009
woodchuck789
  • 4059 Answers
SOURCE: Water is not dispensed but icemaker is working
It's more common to be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws
If it doesn't come out then disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If the water comes out then check the reservoir.It's behind the crispers in the fridge.
Posted on Sep 07, 2009
Testimonial: "As I posted, I'm not sure what the problem/solution was, but its working now. Thanks a lot for pointing me to the crisper!"
What this can be?
On the rear of the refrigerator, there is a water control valve, that controls the flow of water to the icemaker and the water dispenser, if equipped. Hard water is usually the cause for this to quit running. The icemaker and water dispenser, are two separate circuits, and each one has it's own water control valve.
Mar 13, 2015 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator water dispenser is not working. I
In the back of the refrigerator there is a water inlet valve. It will have three hoses one coming in, two going out. A 1/4 line for the icemaker and a 5/16" for the water dispenser. If your icemaker is working and you dont have water at the door the valve to the water dispenser is faulty, you need to replace the water inlet valve. If neither icemaker or water dispenser is working chek your water supply line
Feb 22, 2010 | Refrigerators
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Jenn-air side-by-side water dispenser leak
Check the fill tube to your icemaker and see if it has ice in it or in the fill cup to the icemaker. Most of the time when this problem happens it is the icemaker spraying the water. It could also be a bad module on the icemaker which can get stuck in the fill position and spray water all over the freezer.
Sep 14, 2009 | Refrigerators
Icemaker works; water dispenser not
You can get to it, it is just a matter of figuring which valve has gone bad. You may need to disconnect different lines and actuate the water dispenser to see if water comes out of the valve. You gain access to the valves from behind the machine by removing the access panel that is at the bottom
Jun 16, 2009 | Amana SXD524VW Side by Side Refrigerator
Water not going into icemaker. Water dispenser works fine.
Check the water valve at the back of the fridge if present.
Even if you used blowdryer, ensure that linse are not frozen by performing a complete defrost.
Disconnect water lines from icemaker, and blow with compressor if the above did not work.
May 20, 2009 | Kenmore Refrigerators
Water dispenser doesn't work but icemaker works fine
TAKE A HAIR DRIER AND HEAT UP THE RESEVOUR INSIDE OF THE REFFRIGERATOR BY THE OUTLET UNTIL THE WATER STARTS TO FLOW. GOOD LUCK
Jan 11, 2009 | Maytag MFI2568AE Side by Side French Door...
Nov 25, 2008 | GE GSS25JEMWW Side by Side
GE Monogram ZDI15C Automatic Icemaker Logo
13 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
