Monitor mode only says cannot display this video mode change computer display input to 1600x1200@60hz
  • 26 Answers
That is normal notification, which means your monitor doesnot support to higher resolution. so change screen resolution to 1600x1200 to fix this problem.
Posted on Apr 29, 2014
venexcsd
  • 1185 Answers
SOURCE: monitor says: no signal input check video cable .
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Posted on Jun 27, 2009
budmrtn
  • 11361 Answers
SOURCE: my computer display screen starts with the message
You need to set your PC video resolution to this monitor resolution, which is 1920x1080@60hz. You can do it by bootup in safe mode (hit f8 key while booting up), then select boot with VGA, once bootup, set the new resolution 1920x1080@60hz or something lower such as 1280x768 for now, reboot in regular mode, and reset resolution to 1920x1080@60hz. You may have to install driver if the 1920x1080@60hz does not show up in the list.
Posted on Apr 24, 2010
budmrtn
  • 11361 Answers
SOURCE: installed Dell 1905fp monitor -- message showing
The native resolution of this monitor is 1280x1,024 2 60Hz, your PC video card resolution is set too high for it to display. Bootup in safe mode (hit F8 while booting up), then select VGA support, set the resolution to 1280x1,024 2 60Hz, then reboot.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 09, 2010
SINN3D
  • 85 Answers
SOURCE: Monitor display message : = No Video input. Pls
if cables are ok; Take your computer down to the repair shop.
Posted on Jun 20, 2010
budmrtn
  • 11361 Answers
SOURCE: I have Philips 170S LCD monitor. When I connect
You need to lowe the resolution AT your GADMEI Combo TV box, not at the PC since you are using the Game box to drive the monitor.
Posted on Feb 17, 2011
I've got a Philips 221V mnitor and it diplays:
boot your pc , keep on pressing f8 key then select safe mode option, remove the graphic driver, then shut it down, then again start install the graphic driver
Jul 28, 2011 | Philips C.927126 Monitor
My monitor says input not supported
Monitor says 'input not supported', means the computer is sending an incompatible display mode to your monitor. Please check the user’s manual for supported display mode or input and configure your computer to those settings. The recommended setting for LCD panel is 1024x768 resolution and you may need to change the refresh rate of the monitor to 60Hz.
In Safe Mode, fire uop regedit and ry going to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Class\Display and delete that whole key (yes, this bascially will remove your video drivers) then reboot, when you reboot windows should start up in standard VGA mode and prompt you for the video card drivers.
For more, refer to this forum;
http://www.pcguide.com/vb/showthread.php?t=24178
Regards,
Anirban Mazumdar
Jun 04, 2010 | Computers & Internet
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
Cannot Display This Video Mode!!!
Restart your computer Press F8 key it shows Startup option choose VGA mode and Select the resolution after getting your desktop
May 06, 2010 | Dell Inspiron 530 Desktop Computer
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
No display.
http://support.dell.com/support/edocs/monitors/2005FPW/En/setup.htm#Using%20the%20OSD
Make sure the proper input is selected
1: D-SUB for Blue VGA cable
2: DVI-D for White DVI cable
The option selected should be indicated on the power save screen.
If changing the input select and rebooting the computer have no effect an no video from the computer is ever displayed, then the monitor is in need of repair.
Jun 30, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
