Question about Telex Radio Communications
Repair 5x5 Pro III
Ear piece quit working
Need to hard reset motorola mini bluetooth h9
try removing the pairing to your phone and pair again. If this does not work try pairing your headset to another phone and if it does it on that phone then something is wrong with the earpiece return for repairs if under warranty or if you are willing to pay for the repairs if out of warranty or replace ear piece all together as they are reasonably priced these days. If the ear piece works fine the other phone something has gone wrong with the bluetooth side of your phone return for repairs or replace depending on what you can afford to do. I hope this helps.
Aug 26, 2012 | Motorola Mobility H9 Mini Bluetooth...
I now have 2 Voyager Pro+ wireless ear pieces that have quit working within 2 months of activation. No LED light at all when hitting the on/off switch, when power is plugged in no LED on one, I get an LED...
If the units were just purchased I would suggest having them replaced by Plantronics. The Voyager Pro+ has a one year warranty through Plantronics. The link below is for Plantronics online replacement form.
Plantronics Replacement Form
Good luck from Headsets Direct!
Aug 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
Bold 9000 only rings through the ear piece when it is connect. Does ring when disconnected to ear piece. When ear piece is not in my ear, I can not hear the phone ring.
Hi, what makes it when disconnected to ear piece. When ear piece is not in my ear, you can not hear the phone ring is because the ringer of the phone that makes you know when there is an incoming call on your cell phone or a message alert tone on your cell phone is damaged and does not work and makes sound to notify you .
The ringer is a tiny speaker inside the cell phone that allows you to hear incoming call from your cell phone You will need to replace the ringer inside the cell phone ....
When you replace with another ringer (speaker inside the cell phone),phone will be Ok again.
Would advice that you contact an expert in phone repairs for asistance,that will do you good to prevent more damaged on the phone...
Take care.....
Feb 09, 2011 | RIM BlackBerry Bold 9000 Smartphone
My dog chewed on earphone and the sound is all crackly. Is it possible to get one fixed and what would it cost?
HI. If your dog chewed on the actual hardware and wire strands, this will not be repairable. The strands that carry the actual sound data stream have been compromised and separated from the main strand that runs through the ear piece. This type of trauma cannot be repaired, unfortunately. You will need to replace the entire ear piece set. I can understand that you want to repair and not replace, but this will be the only option in your case. You will need to replace the entire ear piece set or deal with that deteriorating sound quality.
Aug 30, 2010 | Bose in-ear headphones - Black with...
Can't hear throu ear piece. Only on speaker phone
That's a common problem.It may not be the problem of your ear piece.Try to use it on other phones.If it works then there are two possibilities
1.your ear piece socket is not working
2.your phone is not recognizing the ear piece.In this case reinstalling the firmware (from any service center) of your phone fixes the problem.
May 04, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
Everything is working fine except the ear piece
The other post refers to the process that allows you to use speaker only, instead of automatically selecting earpiece. Unfortunately, this will not resolve your issue, as it appears that your earpiece has a loose connection and must be repaired, or you can continue to use speakerphone, bluetooth (if capable), or wired headset.
Oct 09, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Left cable came out of ear piece too
It is a very fiddly job and would need some very fine soldering even if you could open it without damage as it is very likely sealed !
Best option is to bite the bullet and get a new pair..
Preferably a different make !
Sep 12, 2009 | Ultimate Ears super.fi 5 Pro Consumer...
I have a set with one ear piece working
I don't have one, but are you sure the ear piece itself is bad? Usually, the problem is in the plug, cord, or termination at the ear piece. Troubleshoot with an ohmmeter (pocket DMM has one) and repair with a soldering iron.
Jun 25, 2009 | Beyerdynamic DT 531 Consumer Headphones
Radio Communications Logo
Top Telex Radio Communications Experts
Mike Charette
Andrew Taylor
Andrew Taylor
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
