Question about Microwave Ovens
Kmo-13g watts watts
What is the conversion on a light bulb that says from Hungary?
Watts are watts. 29 watts anywhere are still 29 watts. No conversion.
Feb 23, 2016 | In Microwave Ovens
Watts to fahrenheit
There is no such conversion.
Fahrenheit is a temperature scale.
Watts is on an energy scale. A 100 watt device will raise a small item's temperature only if left on for a period of time. That same 100 watts will have a hard time raising the temperature of a house even if left on a long time.
Feb 16, 2015 | Panasonic Microwave Ovens
How many watts does my panasonic nn7558/6558 microwave have
two ways to answer this question...are you asking for watts being used at the source (plug) or watts being used to generate the microwave transmitter? If it is at the plug then you should be able to take the information located on the back panel that states the voltage and amps required to run the product and multiply both variables to receive the wattage volts*amps=watts.
Sep 23, 2014 | Microwave Ovens
Jvm1631 watts
you can use your owner manual or download from www. retrevo.com or www.manualslib.com or use this formula P =EX I P=watts E=Voltage I= AMPERS you can find the watts in your microwaves.\\God bless you
Dec 08, 2013 | Sharp R-2M58 Microwave Oven
When I turn on microwave oven fuse is burn out right a way. Thank you
Fuses burn for a reason: because the circuit is being overloaded. There could be several causes, first determine what else goes off when the fuse blows. All of the things that go off when the fuse is removed/blown/burnt are on the same circuit. A microwave is a heavy load, somewhere between 750 watts and 2000 watts, depending on the microwave. Remove other heavy loads (items which use lots of power) from the circuit. A 15 amp 120 volt circuit in a residence is good for 1800 watts (or 1440 watts continuously). If you had a 1500 watt microwave and four 100 watt light bulbs on the same circuit, you would be overloading the circuit. With a microwave, it is best to have it on its own circuit with nothing else (if possible). The fuse may also blow or burn in this situation if there is a problem with the microwave.
Oct 05, 2011 | Microwave Ovens
I love my KMC brand microwave. Model # KMO 24G. It's 23 years old this month. I'd really like to fix it. The power button has stopped working. I could get it to work for a while by just holding it down,...
What you may need to do is to clean the touchpad membrane as after a while, grease, condensation, and other foreign articles could be causing the touchpad to be dirty and not function. You can clean the touch pad with methylated spirits, but please read up and learn how to discharge a high voltage capacitor as they can store a very dangerous amount of charge and cause fatal injury, if not death, so please be careful. I hope this helps.
Aug 29, 2010 | Microwave Ovens
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
I have a GE Profile ModelJVM187OSK04 Serial # DM902972B The bulbs went out, they are 120 volt 20 watt. Can I use a GE 120 25 watt bulb as I am having trouble finding a 20 watt??
You should be able to use the 25 watt bulb as long as they are compatible with the socket they mount in... Hope that helps...
Aug 16, 2008 | GE Microwave Ovens
Microwave Ovens Logo
24 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
