Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
AKAI PT5598HDI Colors out of line and picture is bowed in on bottom and top.
    Problem Solver:
  • 3 Answers
Http://www.fixya.com/support/t1663670-akai_samsung_pt4299hd_convergence Adjust the convergence manually. It's a pain and takes alot of patience. The diagram for the remote buttons helps a lot. If it won't adjust you'll have to replace a part inside the tv. Good luck! Hopefully it'll adjust.
Posted on Jun 27, 2009
Picture looks like it is warped at the bottom and top of the picture. Have picture, no problem there, just not a centered picture anymore. Looks like the top of a half moon on the top and botom.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself.
Dec 28, 2010 | RCA HD52W59 HDTV Projection Television
I have an akai 55" projection tv and the top and bottom of the picture is bowed with green and red colors which makes it look like a 3-D movie. how can i fix this problem and what will it cost to fix and...
The tv have a problems known as a convergence problems,it dead.Yes,try website like Tvrepairworld.com to buy a whole rebuild convergence board for the replacement.The Akai/Samsung use the same tv convergence board.The board around $200.
Sep 09, 2010 | Akai PT5598HD 55" Rear Projection...
Getting a 3d image picture and a bow at the top and bottom of screen what is it?
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Feb 03, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
Bowed blue and red colors on t.v. akai 42in hdtv 1080i
You probably have a convergence issue. Since you did not include your make/model there's not a lot that we can do to help you. Try searching your model number with the word convergence in the search criteria.
Dec 06, 2009 | Televison & Video
Screen is bowed on top and bottom.
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
Jul 13, 2009 | Samsung PCL5415R TV
Bowing of picture at top and bottom towards center.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Akai model pt5598hdx/sms
it would sound like your convergence amp power board has failed at the shop we would replace then it would need a serviceman alignment
Jun 17, 2009 | Akai PT5598HD 55" Rear Projection...
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Blurred colors and bowing top and bottom
the problem is the convergance and would need to have the amps replaced. may be some resistors as well. the repair may cost $350.00 or so. there is no bulb inside just three CRTs which are no longer available for your set.
Mar 02, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
383 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
