Question about Vehicle Parts & Accessories
Saab 9-5 bulb replacement 2012
Head light
  • 50 Answers
Lift hood (bonnet) For RH unclip battery cover; For LH move air intake.Unscrew plastic cover anti clockwise to gain access to bulb. Disconnect wiring,undo clip and remove bulb. Fit new bulb in reverse order taking care not to touch glass with fingers and ensure bulb seats properly.
Posted on Aug 26, 2015
How to change head light bulb, drivers side, 2006 Saab 9-7X
Easiest way is to stick your hand in front of the battery and take the dust cover off, twist the bulb and done. I'm lucky, have smaller hands! lol, If you can't get to it, remove the battery for easy access.
The passenger side requires removal of the aircleaner box.
Mar 25, 2015 | 2006 Saab 9-7X
Headlights wont work and dash and parking lights come when ignition switch is turned on. sometimes jiggling wires works. what is the problem?
Check out related help links with solutions to troubleshoot these problem.
Click the link below directly:---
Heater fan and headlights will not turn off with ignition off? http://technoanswers.blogspot.com/2012/01/heater-fan-and-headlights-will-not-turn.html
High beams stopped working but headlights still work?
http://howtobyme.blogspot.com/2011/11/highbeams-stopped-working-but.html
Only one head light works on 2001 Dodge Caravan? http://howtobyme.blogspot.com/2011/11/only-one-head-light-works-on-2001-dodge.html
Headlight Assembly Removal On Honda Accord http://technoanswers.blogspot.in/2012/06/headlight-assembly-removal-on-honda.html ------------- Honda Headlight Assembly Removal
http://schematicsdiagram.blogspot.in/2012/06/honda-headlight-assembly-removal.html-----------
All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
Headlight wiring diagram for 1997 Lincoln Town Car?
http://technoanswers.blogspot.in/2012/02/headlight-wiring-diagram-for-1997.html
Dash Lights And Front Marker Lights Flashing On And Off http://schematicsdiagram.blogspot.com/2012/10/dash-lights-and-front-marker-lights.html
---------- 2001 Chevrolet Tracker: Headlights and Dash lights Pulsating? http://whoisbyme.blogspot.in/2012/06/2001-chevrolet-tracker-headlights-and.html
--------- No parking lights and headlights not turning OFF? http://technoanswers.blogspot.com/2012/01/no-parking-lights-and-headlights-not.html
------------- How to replace HID headlight bulbs for lexus 400h? http://schematicsdiagram.blogspot.com/2012/01/how-to-replace-hid-headlight-bulbs-for.html
--------- Head Lights Comes ON by Itself? http://whoisbyme.blogspot.in/2012/07/head-lights-comes-on-by-itself.html
--------- Only high beams work but head lights not working on Ford F350?
http://howtobyme.blogspot.com/2011/11/only-high-beams-work-but-head-lights.html
Only high beams working on GMC Savana?---------
Working of Headlight switch?
Both headlight bulbs blow together?
Car headlight bulbs don't last long?
How to replace Headlight Bulbs on Lincoln Town Car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-headlight-bulbs-on.html
How to change headlight?
http://repairhelpcenter.blogspot.com/2011/12/how-to-change-headlight.html
Both headlights and turn signals not working? http://schematicsdiagram.blogspot.com/2011/12/both-headlights-and-turnsignals-not.html
Headlights will not turn OFF on Ford expedition and car trailer?
http://technoanswers.blogspot.com/2012/01/headlights-will-not-turn-off-on-ford.html
Headlight Assembly Removal on 2010 buick lacrosse? http://technoanswers.blogspot.in/2012/04/headlight-assembly-removal-on-2010.html
--------- Headlights flickering and car hesitates to start?
http://howtobyme.blogspot.in/2012/02/headlights-flickering-and-car-hesitates.html
Hummers headlights flashes while start?
http://technoanswers.blogspot.in/2012/02/hummers-headlights-flashes-while-start.html
Using non-AFS headlamp assembly for AFS assembly?
http://schematicsdiagram.blogspot.in/2012/02/using-non-afs-headlamp-assembly-for-afs.html
How to replace Headlight Bulb on 2001 mitsubishi magna
http://www.howtorepairguide.com/2012/10/how-to-replace-headlight-bulb-on-2001.html
These details will help.
Thanks.
Nov 22, 2012 | 1996 Pontiac Grand Am
Driver side low beam bulb replacement
LOOK INSIDE OWNERS MANUAL IN GLOVE COMPARTMENT.LOOK IN THE BACK INDEX FOR BULB REPLACEMENT.IT WILL SHOW AND TELL YOU HOW TO REPLACE BULB.BE SURE TO WEAR CLEAN LATEX GLOVES WHEN HANDLING HALOGEN HEAD LIGHT BULBS.BECAUSE OILS FROM FINGERS OR HANDS WILL CAUSE HALOGEN BULBS TO OVER HEAT AND BLOW OUT.
Jun 23, 2011 | 2007 Saab 9-3 Aero Convertible
Hi , I have Saab 95 Showing reverse light failure. Could you pls guide how to change the bulbs. Thanks
If wagon, I think this is in the back door. Remove little doors by turning the screws 1/2 turn. These can be tight. Use small flat head to get the doors off. Remove and replace light.
Dec 29, 2009 | 1999 Saab 9-5
2003 Saab 9-5 tail lights out. Replaced bulb no
Could be the circuit board on the back of the tailight... check that first
Jun 17, 2009 | 2001 Saab 9-3
Need to replace tail light
Hiya,Open your tailgate and you will see 2 plastic plugs on the light unit these are covering the 2 torx screws which are retaining the lamp unit remove these screws with the SAAB toolkit and you will be able to slide the unit out to replace your faulty bulb.
Jan 09, 2009 | 2001 Saab 9-3
I need to replace a tail light
Hi,If you open the tailgate you will see two plastic plugs on the light unit prise these out and you will see the 2 torx screws these can be removed with the SAAB toolkit you can then slide the lamp unit out to replace the faulty bulb.
1999 9-3 Turbo front light failure--will not start
uestion; Did you replace it while it was raining?
Nov 23, 2008 | 2003 Saab 9-3
Vehicle Parts & Accessories Logo
50 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
