Question about Sansui 5000x Am/fm Stereo Receiver Am-antenna-rod-assembly
No fm radio
How to connect fm antenna?
How to connect HDTV antenna to an old Sony Am Fm Radio Tv Receiver, Model Tv-413?
yes there is an coax to ant adapter. Check walmart or Radio Shack if they are still in business.
Apr 06, 2015 | Sony Am Fm Radio Tv Receiver, Model...
Am works on radio but fm does not
FM requires a good antenna connection. Check the connection at both ends, and check for any damage to the antenna cable. If you have the rear mounted power antenna, the cable runs forward under the carpet to the dash.
If the antenna is good, then the FM section of the radio has failed.
Jun 29, 2014 | 1994 Chrysler Concorde
Why does my 1991 Jetta only pick-up AM radio? How do I recieve FM as well?
It's most likely the Antenna connection or the FM bands circuit has burned out. The AM Antenna looks like a coil and is actually in the radio in most models, the FM Antenna is the one built into the windshield or sticking up off one of the fenders or somewhere. Check the connections if you have good connections you'll have to replace the Radio.
May 21, 2011 | 1991 Volkswagen Jetta
Am fm reception bad
FM reception is weak
What to do
• Extend the power cord as much as possible. The FM antenna is in the power cord.
• Move the power cord to adjust the FM antenna
• If you still have problems with FM reception, you may need an external antenna.
* Call Bose®Customer Service to request one.
The external antenna on your radio is a coax (round) design It needs an adaptor and an antenna which are cheap.
Easy to make, radio shack "F" connector 90 degrees or straight, to 300 ohm wire connections. Attatch a 300 ohm flat ribbon antenna cable to those two screws and plug into radio and see how your reception is. You will need to position the antenna wires to get best reception. I have hid them in back of paintings and so on.
Cheapest solution next to putting an extension cord on radio power cord.
Jan 03, 2011 | Bose Wave Radio
Where can i plug my ipod in to my jensen 9410 dvd mp3 receiver
here is what you can use take a rca cable to 3.5 mm cable
thumbnail.aspx?q=410222334008&id=874e2170e5197aa72b7e313258a4fed3 buy a fm modulator
item-3992-5-500.jpg then you can wire up the fm modulator to the jensen radio red power and black ground unplug your antenna from radio plug it into fm modulator and then connect antenna of fm modulator into your jensen radio antenna spot . the connect the rca cables to the fm modulator and then other end into the ear phone piece on ipod . follow the instruction that come with fm modulator you will have to tune your radio to a station like 88.9 or which ever you pick from the select ones fm mod gives you to hear you ipod . http://www.tintingbyfredjohnson.com
Dec 28, 2010 | Jensen VM9510 Car DVD Player
!994 Park Avenue FM radio reception poor. AM signal OK
Check antenna connections at radio and antenna assy.. Poor connections will only receive AM and hardly any FM
Apr 06, 2009 | 1994 Buick LeSabre
Fm stereo
FM radio reception relies on a very good working antenna and cable, AM reception much less so. Unfortunately, the problem could be in the radio itself as there are separate signal processors in it for FM and AM. However, the most common problem is a bad cable connection at the antenna or the radio, or a bad cable itself (corroded, pinched, broken wire inside).
A couple of simple things to check: if the antenna is in the window, it may have become disconnected from the cable at the window. If the antenna is body mounted, could be a bad cable connection at the base of the antenna, and in this case, the base of the antenna could be very corroded.
You could also check the antenna cable from end to end using a continuity checker. If you can't figure that out, you could just try replacing the cable (or body mounted antenna in that case).
Dec 19, 2017 | 1997 Jeep Grand Cherokee
Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Aug 30, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Can't Get A Radio Signal When I Connect A Cox Cable
Hi...
Some cable companies dont put the FM band on cable and some others put an FM trap (which kills the FM band) in line with the cable.
One of those is your problem.
You'll need to buy a FM antenna
Jul 25, 2008 | Sony STR-DE597 Receiver
Connect sirius fm adapter to 2008 honda civic sedan radio
You should use the direct FM box to get the static to go away. You unplug the antenna from the radio, plug the antenna lead from the box into the radio, the antenna line plugs into the box. You will have a mini jack that plugs into your radio or dock.
This way you can switch it on any station to get rid of the static.
You shouldn't need to take the dashboard out to get to the radio. Usually you have to take the trim pieces in front of the radio to get the antenna line out.
Sometime you can reach it from the back of the radio if there is enough clearance to get cak there.
Jun 12, 2008 | Sirius Sportster 4 SP4-TK1 Satellite Radio...
Sansui 5000x Am/fm Stereo Receiver Am-antenna-rod-assembly Logo
18 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
ashburton
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
