Question about Quasar VM-D51 Camcorder
What kind of cord to i use to play my cam corder on tv
To view recordings on tv
I cant seem to finalize the mini dvd on my canon dc330 cam corder
Make sure you are in the mode to view the videos you recorded and make sure the camera is plugged in to the power supply, then the finanlize option should be available
Sep 14, 2009 | Canon DC330 DVD Camcorder
Hi.. I have a jvc 32 X cam corder that i want to down load my videos onto my computer and am not sure how..
Two things here. Is your cam corder a digital one? If so there should be a connector on it for either firewire or USB, and if not, you will need some kind of video capture device if your cam corder has outputs on it. If not, you will need a player (vhs-c or 8mm or whatever your format) that can send out to the computer. Once this connectivity is done, you need video capture software that will "encode" the video files that will be produced. If your cam corder is already data (hard drive onboard or SCD card recording, you will only have to "demux" the format you have into the format that you are seeking (ie.. MPG to AVI or so on).
I hope that helps you out.. let me know if you need more clarification. It also might help if you give the media you have (VHS-c etc.) and the available outputs that you see on your cam corder. Thanks!
mrstan
Aug 29, 2009 | Video Cameras
Cannot see anything through the viewing lens
I have same prob, check this out:
http://support-sg.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Kiri
Jan 30, 2009 | Canon MV630i Mini DV Digital Camcorder
JVC GZ - HD10AA Camcorder.
Fixya does not run any training courses. What software are you using to create the movies to play on your TV ?
Mar 26, 2017 | Canon ES10V Camcorder
Lost instructions, cannot create DVD from cam-corder recording
Thanks, I already solved the problem. There was no "Setup" button (on the remote, anyway) to follow the instructions given -- in the manual, which I downloaded!.
Instead, I remembered that "Input" often allows you to select a source for something, so when I chose THAT button, I was able to choose the port that had my cam-corder.
Then I simply pressed record on the DVD player while Play on the C-C.
Mark H.
Dec 15, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Transferring vidio from cam-corder to vcr tapes
YOu should have your our from your cam to the input of your vcr and the output of the vcr to the input of the tv... then simply set your vcr to the input channel that your cam is connected to ans it should show up on the tv, if it does not hit the tv/vcr button on the remote ... hit record and our done
Dec 31, 2007 | Sanyo VHR-H607 VHS VCR
Sony ccd tr series no picture in the view finder
camera have problem inside need to open by sony service center near you.
Dec 23, 2007 | Sony Handycam DCR-HC30E Mini DV Digital...
Watching video from cam corder on pc or tv
Try using the movie maker in windows or pinnacle studio s/w
Nov 25, 2007 | Panasonic Palmcorder PV-GS15 Mini DV...
I hook my cam corder up to the my tv it will play but no sound
You are likely using the S-Video cable (multi-pin cable that connects to the front of the camera below the spotlight). This cable carries video but not audio. To get audio, use the multi RCA to 1/8" adapter (has red, yellow, and white cables and plugs into the side of the camera)
Nov 20, 2006 | Sony Handycam DCR-TRV260 Digital Camcorder
Quasar VM-D51 Camcorder Logo
18 people viewed this question
Top Quasar Video Cameras Experts
Josh Whitehead
Josh Whitehead
Michael Allcock
Level 1 Expert
Are you a Quasar Video Camera Expert? Answer questions, earn points and help others
