Question about Sony XL5300 Replacement Lamp for XBR2 SXRD Rear Projection Television
Replaced sony dlp lamp, but red light still is on
I replaced the lamp on my sony dlp sxrd kds-50a2020, & it seems to have worked for about 1 minute, but the red light came back on. Could I have gotten a bad bulb, or is it another problem.
Also, the correct product is XL-5200 replacement lamp, so I had to indicate the product as the Sony XL5300, as the XL-5200 was not a drop down choice below, & I couldn't send this email without indicating a product.
  • BitterTVMan May 11, 2010
    Is the red light solid, or does it blink?
quang123
  • 107 Answers
SOURCE: Sony KDF-E50A10
If the lamp is new it could be the ballast the one is supply high voltage for the lamp you can order that ballast from Sony
Check the lamp if is not damage any where
Cheers
Posted on Dec 11, 2008
quang123
  • 107 Answers
SOURCE: Need instructons for changing Sony SXRD XL5300 lamp.
If you instructions manual you can download from Sony Web
Cheers
SOURCE: TV Wont turn on - Red Blinking Light under Lamp
The lamp is shot. Port is on the right side of set - just remove and take a look. Check VISA limit.
Posted on Apr 16, 2009
welcomejee
  • 10594 Answers
SOURCE: XL 5200 bulb replace and NO Picture or Sound
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
Posted on May 30, 2009
  • 53 Answers
SOURCE: no picture on my sony kds-50a3000 red blinking light at lamp spot
If by noise, you mean a loud, audible pop--then it's your lamp that imploded.
You should be able to just pop off the cover on the side (right side if you are facing the front of the set), remove the internal lamp cover (if present) and yank (I mean, gently pull) out your lamp.
Look for all the bright particles of glass inside your newly imploded lamp. Replace with a Sony original, as these sets can chew through generic lamps very fast.
Now, if by noise you mean something else, please elaborate.
Posted on Aug 01, 2009
Sony sxrd kds-r60xbr1 flashing red light all the time
Are you sure the lamp is pushed in far enough and did you make sure you screwed cover back on tightly?
Mar 13, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
I have a Sony Wega SXRD. First issue was the
No. Could be a bad ballast this time. That is the box that energizes the gas to produce light. Bulb has no filament.
Sep 10, 2017 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony KDS 50a2020. Tv Seems to Dull. not a setting.
Two possibilities:
1. The lamp. When did you last replace it? They will dim over time and lose focus, clarity, brightness and sharpness. If it has been 18-24 months, and this is your main tv, consider replacing it.
It's a F-9308-860-0. They go for about $175.00.
2. Let's say you follow my advice, put in a new lamp and the picture is still dim, dark, dingy and fuzzy? Then you, my friend, need a new Optic Assembly. The thing your lamp shines into and the thing that gives you a picture to look at. They can fail or wear out for all sorts of reasons--too many for me to type out now. But, suffice to say, if you have recently replaced the lamp (less than 6 months) and are experiencing a drop in brightness, consider getting on the phone with Sony. Even if you are out of warranty, your set is covered against Optic failure until June 30, 2010.
Hope this helps.
Jan 21, 2010 | Sony KDS-50A2020 Television
Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
Dec 31, 2009 | Sony KDS-60A2000 60" HDTV
No picture and red light flashing please help
You need a Sony XL-5200 replacement lamp. Flashing red light indicates lamp needs replacement.
Sep 04, 2009 | Sony KDS-50A2020 Television
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
Sony SXRD 60 in. won't power on
You need to replace your DLP lamp...easy fix that you can do yourself.  If, you buy from the Sony website it will cost more.  Try looking online and make sure the lamp is Sony Certified Replacement part and you should find the bulb by itself for $90 - $120 or cheaper or in a rebuilt housing for approx. $160.00
Apr 03, 2009 | Sony KDS-R50XBR1 50" HDTV
Kds-50a2020 sony tv will not turn on
You may have luck in reading the blink code to find your problem at this link.
http://www.agoraquest.com/viewtopic.php?forum=70&topic=31721
Mike
Mar 22, 2009 | Sony KDS-50A2020 Television
Sony XL5300 Replacement Lamp for XBR2 SXRD Rear Projection Television Logo
175 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
