Question about GPS
Rav4 gps Blank screen navigation
2012 yukon xl 15 navigation screen black out
And function work but screen is just blank? If so you must remove the unit from the dash and have it repaired by a GM approved repair center. Google "GM built in GPS repair"
Nov 04, 2016 | GMC 2012 Yukon XL
Did head gasket put it together, now smoke a lot but oil is nice and clean
Head gaskets are not easy, if the smoke is white you still have a coolant leak into cylinders
Mar 19, 2016 | Koolertron For Toyota Matrix & Toyota...
Amcor 3990 GPS navigation device screen backwards
If your screen is actually installed backwards take it back and exchange it for new one, but if the screen is not actually installed backwards then go into the settings screen on the gps unit and find the orientation section, this will change the display to something a little more readable to you. And as a side note some of these things look like they should be straight up and down but they actually designed to work sideways, gives you a wider view and the manufacturer a little more screen room to put more information onto the screen.
Jan 02, 2010 | Navigator Amcor Amigo 4300B GPS Receiver
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
The screen won't light up on my nextar #P3 GPS
press the reset button on the back. i had the same prob.
Jun 09, 2009 | Nextar P3 GPS Navigation System
Gps navigation screen is paralyzed--all other screens are working
hi did you install the software straight to your route 66 maxi using route 66 sync software ? if you did try downloading it to your computer then transfer it on to the memory card using a card reader
Jan 07, 2009 | Route 66 MAXI Car GPS Receiver
Kna-g510 gps receiver not working
I have the same problem, did anyone get to fix it?
Jan 02, 2008 | Kenwood KNA-G510 GPS Receiver
Navigation screen freezes GPS unit
I believe they fixed this problem with a firmware upgrade. Use Garmin's web updater to perform the updates.
Jul 07, 2007 | Garmin eTrex Legend Cx GPS Receiver
GPS Logo
12 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
