Question about Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
TV front control do not work. When pushing front controls nothing happens.
I have a 24 inch sanyo flat screen tv it is stuck on video and when I try to change the channel nothing happens I do not have the remote controller for this tv or any universal controller in general w
tried with unplugging and re plugging the tv doesn't work?. if not, tried to push any button like the channel up/down button and tv/video button at the front panel.
Oct 15, 2012 | Computers & Internet
Light comes on but nothing happens
You need to replace the remote more than likely. Thanks for using Fix Ya.
Jan 29, 2010 | DISH Network 135899 Remote Control
Remote control chkt1a for apex tv does not work properly. None of the functions work even though while pushing the buttons the red dot works but nothing happens on the tv
You may have bad solder joint inside the remote and especially on the l.e.d at the front, happens often(remote dropped etc.). If you have a soldering iron you can open it a make a round of the solder joints, it should fix your problem. Hope this will help.
Dec 02, 2009 | Apex Digital PF2025 20" TV
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Input wont work
push the button for the tv first then push the input should work now
Jul 20, 2009 | Universal Remote Control Hampton Bay...
Duet will not start
HI, The Central Control Unit has failed. you will need to replace this failed control board asap.
We recommended a service call for this type of repair.
Jun 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My LG remote control is not working
Make sure you push the TV button on the top of the remote before you push the power on button.
Dec 17, 2008 | Televison & Video
RCA TV Remote Malfunction
From your post I understand that the tv is not turning on even if you use the button on tv, if that is the case there is nothing wrong with the remote control, and from the blinking light shows that there is something wrong with the tv. Get it checked by a qualified service guy.
Jan 25, 2008 | Televison & Video
Sharp AQUOS LC-40LE830U 40" LCD LED HDTV Logo
11 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
