Question about MDT Harvey Hydroclave SC8
How do you know the voltage requirement of the machine
Is it110v or220volts
Power voltage requirement
Wrong site. I fix home appliances, But you can buy them cheaper than I would fix them for.
Dec 26, 2015 | Cars & Trucks
I need to know how to convert the plug
If you meant that the voltage setting were diffferent, you can use a voltage convertor which is available in the market, choose the correct ampere rating( watts) to suit and also make sure it is a step down or step up as required as these details were not shared by you.
Jun 27, 2012 | Washing Machines
How do I know if the timer module is bad
confirming the timer requires you to test the output and input voltages on the unit and so requires a mulitmeter to test the voltage and also the continuity of the controller switching.
Jun 09, 2012 | Whirlpool Washing Machines
Hello. I have dishhwasher model heds 968 and I am requiring information about Power supply ' Amperios for a breaker, could you send complete information Voltage 220 Volt A.C Amper :_______ A
The solution to your problem is the machine voltage must match to supply voltage, if it does not then you will require a suitably rated transformer to correct this, Note a heavy duty transformer to operate this machine may be expensive the alternative may be to purchase a machine that will operate on the supply voltage provided by your supplier. Hope this is usfull Regards Mike
Jul 08, 2011 | Dishwashers
I'm replacing my gas furnace with a ac/heater unit that uses 240 voltage and want to know how many volts my furnace uses
If it's a 240 volt system, the maximum voltage required is 240 volts. Which would be what the furnace needs/uses to operate properly. But, I suspect what you really wanted to know is what is the amperage that's used/required. In most installations, it requires to 60 amp circuit breakers. However, yours may require less or more. Check the installation manual for more specific requirements.
Apr 04, 2011 | Heating & Cooling
There is a hub and bearing that needs to be replaced you will need to have this serviced by a qualified tech.
You can get the old hub and bearing out but its requires you take machine apart.
As mains voltage is inside this machine you really need to know what you are doing before going too far.
Please dont forget to vote this answer was helpful
Many thanks
Feb 17, 2011 | Kenmore 94872 Front Load Stacked Washer /...
I need to know the power requirements for this piece of equipment. Single or 3 phase, voltage, amps etc.
It is single phase. Either 208 volts 3240 watts or 240 volts 4316 watts. Unfortunately, its difficult to know which one you have. It can be ordered either way. Here's the deal, For no apparent reason, some buildings have 208 volts, some have 240 volts. If you know when you buy new equipment, you specify which voltage you have. So if your building has 208 volts and the machine is 240, it will still work, maybe a little slower to heat up. If it is the other way around, your building has 240 volts and the machine has 208 elements, it will heat up much faster, but the life of the elements is drastacally reduced becuse they burn out much quicker. You can call Lang at 314 781 2777 ask for technical assistance and they may have a way to find the voltage if the tag is missing.
Oct 19, 2010 | Lang Manufacturing PB-24-S
My washing machine and dryer is not working. Where
check the required voltage i think your voltage is different than usa it could be as simple a switch i would look on the back of the machine to see what voltage it operates on and call an electrolux dealer
Apr 12, 2010 | Electrolux EIFLW55HIW Front Load Washer...
I am trying to hook up a 3 prong cord into the dryer but I dont know how you hook up the ground wire.
What voltage does the dryer require? There should be a 'nameplate' somewhere on the machine that has the voltage and Gas requirements. (if it isn't a gas dryer then it'll probably be 240 volt. If it is a gas dryer then a standard 120 volt cord should work). Be sure you are attaching the proper cord... The ground wire should be crimped into a ring terminal connector or a spade terminal connector (can be picked up at any hardware store) and screwed onto any metal surface of the machine(there may be a green screw designated for the ground wire connector)
Mar 06, 2010 | Dryers
I live overseas, and brought this sewing machine
its not transformer or machine problem at all.all the connections are also proper.its the power issue the required power to the machine is not getting from the electric outlet.just call the local electrician and check out the power supply voltage from the electric outlet.and power required to the machine which will be listed on the machine.if more power is required he will connect the over power IC and get the machine work.if less power is required he will connect the RESISTOR and lower the power to the machine and make it work.
Aug 30, 2009 | Simplicity Sewing Machines
MDT Harvey Hydroclave SC8 Logo
75 people viewed this question
Top MDT Medical Experts
Electro Med Services...
Rhonda Webster
Rhonda Webster
Are you a MDT Medical Expert? Answer questions, earn points and help others
