Question about Westinghouse SB915
Dishwasher not heating
Dishwasher still not heating after changing heating element , thermostat , pc board , no power getting to thermostat .
    Champion:
    Habit-Forming:
  • 210 Answers
I am guessing the hot water is not hooked up. Depending on the type of dishwasher and the setup of you kitchen, you can try to hook it up. You will need to pull it out to fix the heating.
Elisa Jed ' http://www.orlandoac.com/
Posted on May 20, 2014
Water does not heat
it could be your thermostat or heater the only way is to test both with a mutimeter on ohms and you should get a readihg if ok no reading means one or both have gone open circiut
Nov 24, 2011 | Electrolux 24 in. EDW5505EPS Stainless...
Not drying. is there a safe way to test the heating element?
Hello there
Here is a detailed list of things to check to ensure that the element is your problem cause there could be a couple of different things also click on the blue items
If the dry cycle has a problem, check these: Heating element Drying fan Thermostat Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element. Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it. Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
Best regards mike
Apr 12, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher wont change cycles.
its might be your heating element or the thermostat check if the heating element get hot if not theres your problem...
the machine try to get to sertion temperture and cant do that so it stuck in the same mode...
heater # 8572861 coast 20-30$
Thermostat Number: 661566 = 14$
hop it helps
Jan 22, 2010 | Whirlpool DU1055XTS Built-in Dishwasher
Idl350 dishwasher fitted a new element but it wont heat the water
check the safety thernostat under the tube you gain axcess to it by removing the lowest panel they are small and round with 2 wires to each shut off power b4 you check by ohms if good
Sep 01, 2009 | Dishwashers
My indesit dishwasher won't heat the water. I
HI. this is actually a control issue. your element is ok. replace the control board or timer module asap.
Aug 27, 2009 | Dishwashers
Heater element problems
Why did you decided that it is an heating element problem,it could be a thermostat issue as well. Check with a multi-meter whether you have power on the heating element tags. In case you have power on its tags, the heating element should be replaced.But in case you can't read any power on its tags, it's probably a thermostat issue. Good luck!
Sep 10, 2007 | Hoover 24 in. DT999 Free-Standing...
Bosh exxcel dishwasher heater problem
Check with multi-meter for power on the heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck!
Sep 09, 2007 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher element and thermostat
Check with multi-meter for power on heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck !
May 31, 2007 | Hotpoint 23 in. BF41 Built-in Dishwasher
Westinghouse SB915 Logo
226 people viewed this question
Top Westinghouse Dishwashers Experts
JonSnell Electronic
JonSnell Electronic
Are you a Westinghouse Dishwasher Expert? Answer questions, earn points and help others
