Question about Watches
How to turn off backup alarm on 2014 Kia Sedona
Back up alarm 2014 Kia Sedona
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    How to turn off the alarm.?
    Hi pink_jean24,
    To turn off the chime and alarm: Press bottom left until in the alarm screen. Then press the top right button repeatedly until the CHIME or CH symbol is gone and/or ALARM or ALM to disappear, then press the bottom left button to go back to main time.
    Hope it helps.
    Thank you for using FixYa.
    May 14, 2011 | Timex 1440 Nylon watch
    Trying to find a manual for accutime US polo association watch not sure model name but mans D44 us8139 12499 on box. Would like to know how to get alarm not to go off.
    I just have to say, we bought the same watch in 2014, at a Meijer store. The directions were totally incomprehensible, and this watch has spent every day since in a drawer where the alarm goes off at the same time each day because 4 intelligent adults can't figure out how to change the settings. Ridiculous.
    Sep 13, 2010 | Bulova Watch
    Can't get the Hourly chime to shut off - tried going to alarm, then hitting adjust Button - alarm shuts on or off , but not Chime
    using the mode button (lower left, go to the alarm. once at this screen, hit the "12/24H" button (lower right). now hit the "adjust" button (upper left), that should toggle the hourly chime on and off. you'll see the bar next to 'SIG'. when it's lit, it's on, when it's blank, it's off.
    Oct 27, 2009 | Casio Illuminator AQ150W1EV Wrist Watch
    Can't turn off alarm
    Here are the instructions to view, change alarm time and turn off alarm:
    From normal time display:
    Press MODE once to display stop watch.
    Press MODE again to change alarm time.
    Press MODE again to change time.
    Press RESET once to display current alarm time.
    Press and hold RESET then press START to turn on and off alarm (watch for alarm symbol on top left)
    Press and hold RESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
    Hope this helps.
    May 05, 2009 | Watches
    Timex Expedition alarm beep
    good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
    Aug 28, 2008 | Timex Digital Expedition watch
    WR30 Wristwatch
    hello,if you have the little circle window on the left of your face,that will tell you if the alarm and chime are on.
    to turn them off you must push and hold the lap/reset button and at the same time push the st./stop button:
    1 time takes of the chime-hourly beep
    2 times takes off the alarm tha you set
    3x's puts the chime back and 4x's puts the alarm back on.
    Jul 21, 2008 | Timex 1440 53591 Sports Quotient...
    No Alarms After Changing Battery
    you have lost the alarm spring or put it in wrong spot. it touches the alarmplate in the case back. in some models if the back is upside down same problem.
    Mar 26, 2008 | Casio W94HF-3AV Wrist Watch
    Unwanted alarm
    using the button at bottom left of watch, set to the alarm mode and press the button at bottom right to toggle between alarm settings. The bell and wave symbols will appear and disappear on top left of watch display.
    Jan 08, 2008 | Oregon Scientific SE233 Wrist Watch
    Watches Logo
    63 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
