Question about Diamondback Cycling
How to fix right side gear selector on diamondback 7005vectra
Gear selector lose an doe sent work
  • 51 Answers
SOURCE: sprinter gear selector
This is the gear linkages. It is a cable operated system to allow the gear lever to be dash mounted.
They are a common fault. The parts are about £65 from Mercedes (dealer only part) and unless you know what you are doing you can expect about 2 - 3 hours labour charge, though there are no special tools involved.
They average about 60,000 miles, though the replacements tend to be better.
Posted on Mar 28, 2009
  • 1810 Answers
SOURCE: Forced gear selector - now Spectra will not start
yes yes yes there s a newtral parking switch in those and you eitho bent or broke it off try puting the car in newtral not newtral you can see just go by feel shift the car into l1 try it then l2 try it
then d try it heck even try reverse and newtral
failing that you need a hays manual and a lot of time to crall arround eithor under your dash or hood depending what the book says
happy hunting and good luck
btw thats why all cars come with a parking or hand break dont be afraid to use it b4 you put your car in park it will save you a lot of problems in your tranny like bent parking pins from some moron bumping your car or just a hill or incline.
Posted on Jul 23, 2009
  • 4102 Answers
SOURCE: My gear selector is locked up.
Hi it sounds like the problem is with the clutch unless you vehicle is auto if its auto box then the chances are this needs replacing if you have manual gearbox then i would get the clutch replaced or looked at.
If the clutch is ok then it could be that the gear selector inside the gearbox is worn and needs replacing if this is the case then it would be cheaper to get a reconditioned gearbox as repairing it would cost about the same as a recon.
If you need further assistance then let me know ok
Posted on Aug 05, 2009
  • 133 Answers
SOURCE: P0705 code gear shift selector (PRND3L)
Usually replacement of the (pnp) position switch will solve the problem.
Posted on Mar 14, 2010
  • 14036 Answers
SOURCE: renault trafic 100 dci gear selector
check transmission shift selector lever mounting bolts.either mounting bolts are loose or the shifter broken
Posted on Dec 01, 2012
Kx 85 is only selecting first gear how can I fix it
Selector shaft is worn or has come away from the selector barrel which changes the gears. It's an easy enough fix, you will need to remove the right-hand side engine casing. When you have this off, get someone to move the gear selector up & down while you look behind the clutch to the left to see if the shaft has popped away from the barrel or is possibly worn out.
Dec 16, 2014 | Motorcycles
What would cause my 2008 suzuki ozark 250 atv to jump into neutral then not shift
Sounds like you have either a busted shifter fork. Or the pin in the gear selector has broken off or the bolt as come loose in the center of it and the pin has fallen out. If it's the shifter fork it's an expensive teardown. If it's the gear selector it should be an easy fix. Look at the selector gear first but when you pull the side of the engine be careful not to lose any parts.
Sep 03, 2014 | ATVs
2003 kia sedona ignition will not turn
On the top right side of the gear selector there is a cap that covers the inside of the gear selector components, if you pop that off with a flat head screwdriver you can manually disengage the parking brake
Jan 30, 2014 | Kia Sedona Cars & Trucks
My gear selector is really loose
iF YOUR CLUTCH IS WORN IT WILL NOT GO IN TO GEAR CAUSE THE TRANSMISSION IS STILL SPINNING SIDE. ALL-WAIST MAKE SURE CLUTCH IS WORKING . ENGINE OFF 1ST GEAR CLUTCH PRESS IN TRUCK SHOULD ROLL.(HELPING HAND WITH A LIGHT PUSH) IF IT DOES NOT ROLL OR HARD TO ROLL COMPARE TO NUTRAL DO THE CLUTCH. IF IT ROLLS OK INTERNAL PROBLEM WITH TRANS
Jan 19, 2013 | Chevrolet Cars & Trucks
1999 buick century odometer light does not work
this is a common problem and the dash cluster must be removed and sent out for repair, cost is about $175 to replace the LED (Light emitting diode) display that has burned out, this is a faxtory defect as far as this expert is concerned, it is not a fuse problem.
Jun 13, 2010 | 1999 Buick Century
Bike keeps jumping out of gear
Either your gear selector adjustment needs to be re-set (right hand side of motor inside the clutch cover, there is a hook and claw mechinism that can be fine-tuned) or the gear selector drum stopper is badly worn and will need replacing (experts only, as this requires a total engine strip down).
Mar 04, 2010 | 2003 Suzuki RM 125
Cycling Logo
24 people viewed this question
Top Diamondback Cycling Experts
Tony
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Diamondback Cycling Expert? Answer questions, earn points and help others
