Question about HP TouchSmart IQ804 Desktop PC
Enter bios what is the key to enter in bios
    Sergeant:
  • 233 Answers
This depends on your bios.
But the most common are F2 or the Delete key while the machine is rebooting. Just hold the key down and ignore the beeping. till the bios screen displays. Good luck!
Posted on Mar 29, 2014
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Power but no display
try going into bios blue screen press f2 or f10 or f12 on start up beep . change setting in video settings
  1. Watch for a "entering setup" message in the first few seconds after turning on your computer. This message varies greatly from computer to computer and also includes the key or keys you need to press to enter BIOS.
    Here are some common ways you might see this BIOS access message:
    • Press [key] to enter setup
    • Setup: [key]
    • Enter BIOS by pressing [key]
    • Press [key] to enter BIOS setup
    • Press [key] to access BIOS
    • Press [key] to access system configuration
  2. Quickly press the key or keys instructed by the previous message to get into BIOS
Oct 22, 2013 | Biostar Computers & Internet
I have older Toshiba laptop A15-S1292 running XP SP3. Problem is every time it start, before anything can be seen, it ask for password. I know the password, but I do not know how to romove the...
ESC Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key. The computer will display the "Password = " prompt.
2. Enter the correct password, and press the Enter key. The computer will display "Valid password entered, system is now starting up. Check system. Then press (F1) key"
3. Press the F1 key. The BIOS setup program will appear.
4. Using the arrow keys or the tab key, move to the password field, and highlight REGISTERED.
5. Press the spacebar, enter the correct password, and press the Enter key. The Password field will change to NOT REGISTERED.
F2 Key BIOS Password removing procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the F2 key. The unit will display the "Password = " prompt.
2. Enter the correct password, press the Enter key. (You may need to press the F2 key after you hit the enter key.)
3. The BIOS setup program will appear.
4. Using the arrow keys, move to the Security tab, and to Set User Password.
5. Press the F5 or the F6 key to navigate to the Password section. Enter the current password at the Old Password prompt, and press Enter. At the New Password prompt, press Enter (without typing anything into the password field). At the Confirm Password prompt, press Enter again (without typing anything into the password field). The password should now be removed.
6. Press F10 to save and exit from the BIOS Setup program.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 01, 2011 | Toshiba Satellite A15-S127 Notebook
Reset bios laptop ibm thinkpad 2647
Turn the computer off.
Turn the computer on, and immediately look for a message on the screen, e.g.,
press <blah> to enter BIOS SETUP
or
press Enter to interrupt normal startup
Press the specified key. Then, choose to enter BIOS SETUP.
Use the arrow-keys on the keyboard to navigate to 'LOAD BIOS DEFAULTS'.
To reload those settings, just press the Enter key.
Feb 12, 2011 | IBM ThinkPad T20 2647 Notebook
How do i rmove a bio password out of my toshiba satellite m305-s 4910 laptop
B I O S P A S S W O R D
Setting the BIOS Password
There are two main varieties of BIOS used in Toshiba notebooks, each with its own unique method for setting and disabling a password. First, determine which type of BIOS is used in your notebook model, as follows:
Immediately and repeatedly tap the Esc key. If the message "Check System and press the F1 key" appears, then follow the "Esc key BIOS" procedure, below.
If the computer ignores the Esc key when it's powered-on, or if you see an invitation to press the F2 key to enter the BIOS Setup utility, follow the "F2 key BIOS" procedure, below.
Almost all Toshiba notebook computers will respond to either the Esc key or the F2 key when they're first powered-on. The Toshiba HWSetup program (found in the Windows Control Panel) may also be used for setting and disabling the BIOS password. See the HWSetup procedure, below.
To set a BIOS password, start the BIOS Setup program and enter a new password into the password field, per the detailed instructions below. Once a BIOS password is set, it will be necessary to enter it whenever the computer is started, restarted or reset. Choose a password that you can reliably recall, or make note of it in a secure location. If you forget the BIOS password, only a Toshiba Authorized Service Provider can remove it.
ESC key BIOS Password setting procedure
1. Starting with the computer fully off, turn it on by pressing and releasing the power button. Immediately and repeatedly tap the Esc key, until the message "Check system. Then press (F1) key" appears on the screen.
2. Press the F1 key. The BIOS setup program will appear.
3. Using the arrow keys or the tab key, move to the Password field, and highlight NOT REGISTERED.
4. Press the spacebar, and then enter a new password at the "Password = " prompt. Press the Enter key.
5. Enter the password again when the Setup program prompts for it, and press Enter. The Password field will change to REGISTERED.
6. Press the End key and then the Y key to save changes and exit the BIOS Setup program.
F2 key BIOS Password setting procedure
2. The BIOS setup program should appear. If Windows starts, shut down the computer and try step 1 again.
3. Use the arrow keys to move to the Security tab.
4. Use the arrow keys to select "Set User Password". (This 'User Password' is equivalent to what is otherwise called, in this document, a 'BIOS Password'.)
(It may be necessary to set a supervisor password before setting a user password. A Supervisor Password may be thought of as a backup mechanism -- if a User Password is forgotten, the Supervisor Password will allow access to the computer. The next section describes how to set a Supervisor Password.)
5. Press the F5 or the F6 key to navigate to the Password section. Type in a new password at the "Password = " prompt, and then press the Enter key.
6. Enter the password again when the Setup program prompts for it, and press Enter. The password field will now change to indicate that a password has been entered.
7. Optionally, set the Password on Boot feature to 'Enable'. Otherwise the computer may not prompt for the password at startup.
8. Press the F10 key to save changes and exit the BIOS Setup program.
HWSetup BIOS Password setting procedure (This method works for most notebook models.)
1. In Windows, click Start, then Control Panel (or Start, then Settings, then Control Panel).
2. In Control Panel, click on the icon for HWSetup or Toshiba Hardware Setup.
(If neither of these icons are present, download and install the Toshiba utilities for your model from the Service and Support Website, or use the appropriate BIOS Setup procedure above.)
3. Click on the Password tab.
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other
5. Enter a new password at the "Password = " prompt, and press the Enter key.
6. Enter the password again when the HWSetup program prompts for it, and press Enter. The Password field will now say REGISTERED or SET.
8. Close the HWSetup program.
_______________________________________________________________________
Removing the BIOS Password
Follow one of the procedures below to remove a BIOS Password. See the section 'Setting the BIOS Password', above, to determine which type of BIOS your computer has. Once the password is removed, the computer will no longer prompt for a password when it's started. Removing the BIOS Password requires you to enter it first. If you cannot recall the BIOS Password, only a Toshiba Authorized Service Provider can remove it.
HWsetup BIOS Password removing procedure (This method works for most notebook models.)
4. Click to select Registered. Alternately, there may be a choice for User or Supervisor Password. Select one or the other.
5. Enter the current password at the "Password = " prompt, press the Enter key. If the HWSetup app prompts for the current password and then twice for the new password, simply press the enter key three times after entering the current password. By pressing the Enter key only, you are selecting no password.
6. HWSetup should now show that the password is Unregistered, which means there is no password set.
7. Close the HWSetup program.
Trus this is helpful. Please vote. :)
Dec 12, 2010 | YouTube Videos
Password BIOS prompt comes up and do not know what to do.
Type the BIOS password, then press the Enter key.
If you are the Owner of the laptop, and did Not setup a BIOS password, then try this:
1.Type Password, press the Enter key
Or,
2.Type Administrator, and press the Enter key.
Or,
3.Press the Enter key, and do not type anything.
If this is not your laptop, and the owner set up a BIOS password, you are locked out.
Dec 20, 2009 | Toshiba Satellite 2415-S205 Notebook
How to enter bios
Hi...
To enter bios it so easy. When you turn on your computer you just only press delete to enter bios. If the bios does not exist you can press also F2.
Regards
PCmania
Aug 10, 2009 | ASUS Computers & Internet
Lost pass word
How to enter the BIOS or CMOS setup.
Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Solution: Because of the wide variety of computer manufacturers and BIOS manufacturers over the evolution of computers, there have been numerous different ways to enter the BIOS or CMOS Setup. Below is a listing of the majority of these methods as well as other recommendations for entering the BIOS setup.
Notice: If you are unable to get into the BIOS or CMOS setup because of a password please see document CH000235.
New computers Thankfully, computers that have been manufactured in the last few years will allow you to enter the CMOS by pressing one of the below five keys during the boot.
A user will know when to press this key when they see a message similar to the below example as the computer is booting. Some older computers may also display a flashing block to indicate when to press the F1 or F2 keys.
Press <F2> to enter BIOS setup
Tip: If your computer is a new computer and you are unsure of what key to press when the computer is booting, try pressing and holding any key on the keyboard. This will cause a stuck key error, which may allow you to enter the BIOS setup.
Or you can try this:
Click Start
Click Control Panel
Click User Account
Click on : Computer Administrator
Dec 04, 2007 | HP Pavillion ZV6000 Notebook
OPEN PASSWORD BIOS
How to enter the BIOS or CMOS setup. Reasoning: IBM compatible users may need to enter the BIOS or CMOS setup to setup or change how their computer's hardware is currently configured.
Should get ya back on line , Good Luck
Dec 01, 2007 | Fujitsu LifeBook C4135 Notebook
HP TouchSmart IQ804 Desktop PC Logo
76 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
