Question about BIC America F12 Subwoofer Speaker
Blown f12 amp
Powered sub plate
Do jamo powered subs work in the u.s.a. on 110 volts 60 hz
just buy a adaptor like a normal plug socket that your 2 pin 110 volt can plug into it then plug it in to the 3 pin 240 volt socket an bobs your uncle your sorted.
Jan 25, 2013 | Jamo A320 Hcs6 Home Theater Speaker System...
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Quest subwoofer pops every 40 seconds or without any input. Does not produce any bass or output
Problem may be a blown internal amp module. Some JBL powered subs have this same problem, emiting a burst of noise from time to time even when no signal is being sent to them. I've tried fixing this problem before with only marginal success, even going so far as to install a small cooling fan inside the sub to control the overheating that can destroy these modules. If the module is blown, you can probably replace the whole sub for about what it would cost to repair it. Look into this carefully before you commit to a repair job.
Nov 29, 2009 | Audio Players & Recorders
Can i hook up a powered 12'sub to a Pheonix Gold xs2500 amp without blowing the speaker
First I hope you remove the speaker wires from the speaker that come from the built in amplifire. You cannot hook the powered sub to the amp without doing that first. Then all you need to do is run speaker wire from the sub out of the box to the amp. In no way can you hook up any other part of the powered sub, but the sub itself, to the amp. If you know the wattage of the sub and the ohms then wire it to the amp correctly. Your phoenix amp will put out 125 watts x 2 at 4 ohms and 250 watts x 2 at 2 ohms and 500 watts x 1 at 4 ohms bridged. Remember, only the sub itself in the sub enclosure can be connected to the amp. Hope this helped you. Let me know if you need more help.
Aug 23, 2009 | Phoenix Gold XS2300 Car Audio Amplifier
Subwoofers were said to be bad
overpowered definitely. when you bridge subs your almost doubling the power. if the subs were set for 2000 then the guy he took them too should have known better or at least turned the power down on the amp.
Mar 13, 2009 | Car Audio & Video
DEH-P360 Won't output to rear channels/Sub
Make sure that the FIE (front image enhancement) is off. If it is on, the rear outputs are muted.
Oct 01, 2008 | Pioneer DEH-P3600 CD Player
BLOWN FUSE?
If no warranty - remove amp and check sub to another amp to isolate speaker from internal amp. Either the amp blew a channel or subwoofer blew. JBL's are typically well built. Has this speaker often been pushed loud often?
Apr 23, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Help ASAP Plaese
Are you saying you connected the sony output jacks to your subs directly without any other amp? Are the sub outputs powered? Or line level? Are the subs powered or direct? need some more info please. and post the Manual here if you can. Thanks
Jun 14, 2006 | Sony CDX-M850MP CD Player
BIC America F12 Subwoofer Speaker Logo
96 people viewed this question
Top BIC America Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a BIC America Audio Player and Recorder Expert? Answer questions, earn points and help others
