Question about Altec Lansing VS4121 Computer Speakers
Where would you buy longer wires?
Looking for longer wires, where would I be able to get them?
    President:
  • 3,085 Answers
Radio Shack will have what you need.
Posted on Jun 14, 2009
I'm looking forward to this part of my Craftsman 225 mph blower / vac
Most of the parts that use to be available for that model are no longer available, it is cheaper to buy new one.
Models parts no longer available
136.740360
136.748270
http://www.sears.com/craftsman-2-speed-blower-vac/p-07130376000P?sellerId=SEARS&prdNo=2&blockNo=2&blockType=G2
Nov 01, 2016 | Craftsman Garden
Cant remove starter
this is actually a pretty common problem, i had the same issue on a pickup, i ended up cutting the wires and splicing in and extra 8 inches of wire to allow the starter to drop far enough to gain access the next time i needed to do a starter job on it. you can also wire in quick disconnects once you get to that point to make it easier on you. just make sure you make good, tight connections. you can get the ends you need at any parts store, i used male and female insulated spade connections on mine, havnt have any issues with it since an that was about 15 thousand miles ago. if i remeber right the quick disconnect kit was about 80 bucks and i was just to cheap to spend the money so i made my own. try looking at painless wiring's web site. as far as the main power lead goes dont cut it and try any splicing, if you need it to be longer just go buy a longer one, they arent to spendy. another option may be to remove the exhaust manifold above the starter to gain access or remove the tire and go in thru the wheel well to get to it. hope this helps
Feb 11, 2012 | 1999 Oldsmobile Bravada
My "bake element" is no
turn off the power remove the wires from the elemant and check the element with a multimeter chances are that the element has failed
May 30, 2011 | Ovens
Where can i buy second hand parts for the proform 590hr? I can buy the part i'm looking for £101, looking for cheaper thanks
If your looking for a inductor for your unit it would be unwise to replace this component with used.Since this device keeps current flow at a constant for your drive motor, thus generating heat in these inductors the copper wires are coated with lacquer. Thus over time causing the lacquer to crack and expose the copper wire thus shorting out and further damaging your unit.
May 28, 2010 | Proform XP 590S TREADMILL Drive Motor
Replacing AV Receiver what to buy
Looking to buy new receiver so far only have two that appear to be good value for money and within my budget. They are Marantz NR1501 and Denon 1909. also looking at the Quintet 5-channel Klipsch speakers. This is about as far as I have got but will continue to check out the reviews a little longer before making my final decision.
Jan 18, 2010 | Sony STR-DG510 Receiver
Brand
black and decker is the best brand you can buy it is durable and last longer good luck to you my friend.
Feb 20, 2009 | Black & Decker B2300 Bread Machine
1999 cadillac sts over charging we changed 4 alt, new battery,checked fuses, checked fusiable links,checked belts,checked grounds,HELP!!!!!!!!!!
on the positive battery cable under back seat is a red device with small orange and bule wires called a thermister controls alt output.this device is no longer availible from gm good news is you can buy a resistor of 1600 ohms from radio shack for lees than a dollar plug it in to connector instead of the thermistor and chargeing goes back to normal. radio, windows ,cruise, control should go back normal also
Aug 22, 2008 | Cadillac STS Cars & Trucks
Where to buy parts
From what I believe, Mitsubishi is no longer supplying parts for their home entertainment products. They may have some older stock. I would suggest calling their tech support to find out for sure.
If they do no longer have the part, start doing a google search to see if you can find one on the net. Sometimes there may be someone with a scrapper set, and they are willing to sell parts.
Jerry G.
Apr 28, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Altec Lansing VS4121 Computer Speakers Logo
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
