Question about Bell & Howell Secure Pro Keypad Alarm System
I don't remember how to set my alarm
I lost my instruction sheet for my Bell & Howell Secure Pro Keypad Alarm System.
    Problem Solver:
  • 16 Answers
This is the manual in .jpg/image form. Hope this helps for anyone still looking for the manual .
Posted on Jan 27, 2017
2 Suggested Answers
SOURCE: secure pro keypad alarm system instruction manual
I have a .jpg of the instruction sheet. Will try to attach it here....Image too large. Will try to post to some website.... and 'link' to it. Try this:
Or maybe:
Posted on Sep 23, 2012
Change nsin alarm code
Any one got a instruction book for one of these alarms carnt find mine and carnt remember how to re program it
Nov 18, 2012 | House Brand 2x Intrud Alert House Alert...
Secure pro keypad alarm system instruction manual
It's more about the performance, it is about the fashion. It's about competition. Our team has been dedicating lots of time and efforts to improve the design to bring you this completely stunning product- Beast series. Beast series ESC are well designed and tested and fine-tuned by the experienced driver proven to be a reliable quality ESC. On top of this, we make it more resistant to water. Not splash, it's real waterproof. You can run your vehicles through the morning dew, down the muddy road, across the soggy snow or just about anywhere else you'd be interested in running a 1/8th scale RC buggy or truck. We are using today's state of the art micro components, The ESC delivers advanced tuning options for the ******** racer. Whether you are into large scale or short course, Beast has what racers demand; reliability, precise control and unmatched power handling capability. Also for the sake of safety, we offer you the accurate voltage and temperature protection to make sure you are using within the safe limits. Wide range of parameter configuration and friendly PC interface setting make it even more perfect choice to gear up your vehicle.
1. Enhanced throttle response, excellent acceleration, strong brakes and throttle linearity
2. Using advanced software interface to set up or update the software or using programming card to make adjustments.
3. Using PC or programming card to program forward or reverse throttle limit
4. Using PC to program braking percent
5. Multiple protection features: Low voltage cut-off protection, over-heat protection and throttle signal loss protection
6. Compatible with NOVAK, LRP, ORION Sensored brushless motor
7. MOSFET design provides high-current output (1080 amp peak) with incredibly low resistance (.0003 Ohm)
8. Micro-fin aluminum heat sink dissipates heat.
9. Industrial leading edge waterproof design
Max continuous current: 150A
Burst current: 180A
BEC output: 6-8.4V adjustable, 3A
Motor type: 4 pole sensorless and sensored brushless motors
Battery: 5-18 Cell NiMH or NiCd, 2-6S LiPo
Suitable vehicles: 1:8 on-road and off-road cars/trucks
Operation environment: waterproof design allows you to use in nearly any environment
Resistance: 0.0002 Ohm
Dimensions: 55x48x37mm
Weight: 159g950354dd-f4e0-4d4b-ab97-086bd65e06c0.jpg
i like them
Zgemma Star 2S
kerui alarm
Vu Solo 4K
Headrest DVD player
kerui alarm Store
DLP HD projector
Hikvision Store
Naviskauto Headrest DVD
Hikvision Ip camera
dreambox dm900 hd
May 11, 2012 | Bell & Howell Secure Pro Keypad Alarm...
I have a Napco Gem-P800 Security System and the horn or horns have quit working. The manual says the horn output is 12vdc, checked voltage in alarm mode,but no 12vdc. The schematic shows a 2.2k resister...
First thing its not the resistor. The resistor is there only to make sure the siren wires are ok and not tampered with. Second found this in an install manual.
Bell Test
Enter this command to turn on the Bell, keypad
sounder and keypad LEDs for 2 seconds. The
battery is tested during a Bell Test, and automatically
every *24 hours to ensure proper battery
operation under load. The Alarm output
requires a battery in order to supply the specified
output. If the battery cannot sustain the load, a
low battery indication will be displayed. A battery
test is also performed on power-up after a 3
minute delay.
if the battery fails test replace it and try again.
Assuming no programming changes were made to the zone types that would diable the bell output. if this does not help, time for an upgrade. : ( GL
Jul 27, 2011 | Gemini Sound Products Gemini Napco...
Atomic travel alarm clock. Model number C17D2090 WIC#693047. (No brand name on clock.) I am living in outside US time zones and can't manually reset my clock to the correct time. (I lost the instructions.)...
Instructions to set the C17D2090 atomic clock
A. To manually set the clock
1. Use the CAL/ALM button to toggle the display until it shows the calendar
2. Press and hold SET until the screen flashes "12hr"
3. Use the UP (antenna) and DOWN (alarm) buttons to change the settings
4. Press SET to set the value
This mode will let you set the 12/24 hours clock, the time, date and year. You should be in the right time zone before you start.
B. To set the alarm1 time
1. Use the CAL/ALM button to toggle the display until it shows the AL1 alarm time
2. Press and hold SET until the alarm time flashes
C. To set the alarm2 time
1. Use the CAL/ALM button to toggle the display until it shows the AL2 alarm time
D. To turn on alarm1
2. Use the DOWN (alarm) button to toggle the alarm on and off (a bell appears on the screen)
E. To turn on alarm2
F. To have the atomic clock set automatically
1. Press and hold the UP (antenna) button until a little triangle flashes on the screen
2. Wait for clock to set
3. To give up waiting, press the UP (antenna) button again.
G. To change the time zone
1. Tap the ZONE button to toggle between the 4 time zones
Mar 26, 2011 | Audio Players & Recorders
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions '
Feb 04, 2011 | Audio Players & Recorders
I have a bmw series 328i and lost my keypad but i
Your alarm will go off when you open the door, but as soon as you put your key into the ignition it will turn the alarm off.
Apr 17, 2010 | 1 Series Vehicle Alarm System
Resetting a Bell+Howell Secure Pro Keypad Alarm
We had ours all set up and threw out the manual. When the batteries died then it went back to the manufactures setting. We punched in 4 zeroes and pressed code. Then we put in our new 4 digit code and reset it that way. Hope it helps.
Mar 06, 2008 | Lands Phones
Bell & Howell Secure Pro Keypad Alarm System Logo
272 people viewed this question
Top Bell & Howell Home Security Experts
Lawrence Oravetz
Are you a Bell & Howell Home Security Expert? Answer questions, earn points and help others
