Question about Hobart Stickmate LX 235AC / 160DC Welder without Running Gear
Hobart stickmate LX Welder runs but will not weld
Was welding went to replace rod and strike an ark but no current at stinger
4 Suggested Answers
  • 225 Answers
SOURCE: Welding breaker keeps popping on my Hobart Champion 10,000.
look for short inside unit,start at breaker and work your way back.
Posted on Jul 05, 2009
  • 81 Answers
SOURCE: will feed wire but will not start an ark to weld
Make sure that the ground clamp is securely fastened to the workpiece.
Ensure that the power pin is fully seated into the housing where it receives the current.
Ensure that voltage and amperage settings are correct.
Posted on May 05, 2010
SOURCE: I have a hobart handler 140. wire feeds ,no weld
Check the relay box it small, square, you have to open the little black box but your electromagnetic relay switches probably popped. Thats what was wrong with my lincoln mig weld
Posted on Feb 20, 2015
My Lincoln welder AC 225 -s sounds like it's running DC ? The only way to get a good weld is with running at a higher amperage
Need more information. Are you using reverse polarity? What kind of rod are you using? What size? What amps? Switch ground and stinger see what happens.
Jul 22, 2014 | Welding Tools
Miller welder 330a/bp it will not weld in D/C straight or reverse no ark but will work in A/C its like there is very low volts I was welding and then could not strike a ark
It's likely that your pedal is the problem. Pull the cover and check it electrically - these have been problematic in the past. You can further troubleshoot by selecting constant output and test the output.
Nov 09, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
Welder wont strike and keep an ark
Check the output voltage of the welder (the torch and earth clamp). The voltage should be around 30 to 40 volts. If yu see the normal spark from the rod as you strike, but cannot hold an arc, have a look at your rods, they could be old, damp or incorrect for your welder or the type of work you are attempting.
Jan 19, 2011 | Hobart Welding Tools
WHEN I TRY STRIKE AN ARC WITH A ROD YOU HAVE TO HIT IT 5 OR 6 TIMES TO GET IT TO WELD ITS HARD TO KEEP IT GOING BUT AFTER 4 OR 5 SECONDS IT WILL BURN LIKE NORMAL (USING PROPER AMPERAGE)
Is this on new rods as well as one's you'be been already welding with? Depending on rod types, some will "flux over" the end, after welding insulating the tip. When you're welding at a low setting, with a small rod, sometimes it is hard to start an arc. A 7018 rod is a good example of this. Strike the rod like a woodden match, or drag it on the metal, to expose the rod. It also depends on your welder. Some have settings to help start an arc and then control the current. Older transformer welders arn't that smart and are less forgiving on low current thin metal settings.
Jul 02, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
Will feed wire but will not start an ark to weld
May 04, 2010 | Hobart 500526 Handler 210 Professional...
My Lincoln SA 200 welder will not rev up when I strike an arc.
Need code number to be exact, but sounds like the wiring to the current transformer is incorrect.
Sep 17, 2009 | Lincoln Welding Tools
Where do the leads connect to a hobart stickmate 235 lx
i am just after checking that welder and it shows the the tourch and earth go to the front . type in the make and model on the internet and it will show you a picture of your welder
Mar 31, 2009 | Welding Tools
Hobart Stickmate LX 235AC / 160DC Welder without Running Gear Logo
Top Hobart Electrical Supplies Experts
Steve
Gene Haynes
Are you a Hobart Electrical Supply Expert? Answer questions, earn points and help others
