Question about Sony BRAVIA KDL-46BX450 46 inch LCD HDTV 1080p
Horizontal lines on screenof sony KDL-46BX450
There are horizontal lines across the screen of the tv. the lines jump slightly and cause shadows. want to know if it is the screen or the t-con board
welcomejee
  • 10594 Answers
SOURCE: horizontal blue lines with a slight blue wash in the screen
Its because of Over Voltage of Screen (G2) to Blue CRT.
Take off front lower cover (speaker grill) and unscrew board. There you will need to find Focus Block mounted having 6 control knobs. 3 knobs are for Focus control and 3 are for Screen volts control. Find Blue Screen control knob and turn is Counter Click Wise slightly until bluish shade disappear on screen including few blue horizontal lines.
If you select AV input to adjust that will be fine as you do not need to wait for dark-scene.
Posted on Apr 09, 2009
roety
  • 585 Answers
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Oct 24, 2009
  • 6 Answers
SOURCE: my sony after recording when play shows horizontal
either the tape or the recording head is dirty. use a new tape. if the lines are still there, get a head cleaner tape or use alcohol to clean the recording head.
Posted on Jan 31, 2010
SOURCE: Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Posted on Sep 24, 2010
SOURCE: have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Posted on Oct 18, 2010
My KDL 46HX820 has lines from left to right horizontally
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jul 20, 2015 | Sony Bravia Kdl46hx820 Led Hdtv 1080p 46...
Horizontal lines across screen of sony KDL-46BX450
Sounds like a T'Con fault itself. Re-seat all the incoming and outgoing flat cable wires to T'Con. If it do not help you, replace it with a new one of same part number. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 23, 2014 | Televison & Video
Horizontal shadow line
It sounds to be a back-light fault. Check the backlight inverter board, and back light. To get more details, http://electronicshelponline.blogspot.com/ Pull up older posts.
Nov 30, 2013 | Sony BRAVIA KDL-46W3000 Television
What causes horizontal lines across tv screen
The horizontal lines on the screen is a symptom of failing LCD panel, it will get more lines as time goes by.
Dec 12, 2010 | Sony BRAVIA KDL-52X2000 50 in. HD-Ready...
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Have horizontal lines across the screen and some
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Jan 22, 2010 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
KDL-40S2000 horizontal black lines
Seems T-Con board mounted at top center at rear of LCD Panel is bad.
Local TV tech will fix TV by replacing T-Con board.
Thanks.
Aug 30, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-46BX450 46 inch LCD HDTV 1080p Logo
24 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
