Question about Livestrong Fitness LS13.0T-2 Treadmill
Treadmill will not turn on
The power light comes but the counsel does not get any power
T700 treadmill console not working. Plugged in & worked; reached 3mph & removed safety magnet. Console went black; won't come on. Power switch lights up; lower board led light shows power on.
The treadmill will not run if you remove the safety magnet. Replace the safety magnet and reset the treadmill. Should start working again.
Thanks.
Aug 15, 2016 | Exercise & Fitness
Ironman treadmill repair
Sears sells this unit has the manual and repair parts available as well as will service it for you , if you wish.
Sep 06, 2014 | Ironman Edge Treadmill - Console Control...
I have a gold gym trainer 410 treadmill that by a power out stop working I notice the motor card was burned out so I bought a used one in ebay but still wont turned on what could be wrong with it
you may have a faulty board.Does it have a light on it when you turn it on. If not it is faulty or the power lead is faulty or safety switch is faulty.
If all else fails call a tech to come out and look at it for you.
Sep 25, 2013 | Golds Gym Trainer 410 Treadmill
My t3 treadmill doesn't come out of energy saving.
rese the treadmill and try again.
if the problem persist go to the MENU, and turn OFF .
God bless yo
Jan 14, 2013 | Life Fitness T3 Treadmill with TRACK...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
Aug 13, 2010 | Life Fitness 9100 Next Generation...
Your Problem: jazfit-750 Treadmill motor will not turn on
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
Mar 18, 2017 | Exercise & Fitness
Livestrong Fitness LS13.0T-2 Treadmill Logo
Top Livestrong Fitness Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Tom Chichester
Are you a Livestrong Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
