Question about Pioneer DVR Computers & Internet
E48 error code magnavox
1 recording fine second recording E48 code
3 Suggested Answers
clifford224
  • 1975 Answers
SOURCE: what does an e48 code mean on 1990 cadillac
Below os a description of what code e48 is and basically has to do with the EGR system and your computer doing tests and the tests failing. As far as the other codes I'm not certain to be honest with you. I do know by holding the "OFF" & "LOW" buttons at the same time clears the codes in the BCM and a 7.0 should appear at the end. The .0.7 and the .8.8.8 I am sorry but didn't have any luck with that and really haven't heard of. Wish I could be more help but here is the description on the e48 for you. Hope this helps.
Posted on Mar 14, 2012
SOURCE: Magnavox vhs to dvd recorder mod no zv427mg9a this recorder pal video cassete play time this working ntsc mode( magnavox region code?1?whate can I do pls
https://www.redcross.ie/fundraise/a-gift-in-your-will/
Posted on Feb 04, 2016
Code E48 what part do I need
Good Morning Gerald, thank you for your question!
If you are getting an error code E48, it usually means that the board thinks the door PTC (positive temperature coefficient) circuit is closed. This particular part is the wax motor on the door lock. One of the best ways to determine if this is a false error code is to reset the power to the appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards!
Sep 06, 2013 | Frigidaire Affinity ATF8000FE
I have a Magnavox zv427mg9 a, and when I insert a vhs after like 17 seconds it turns off. What could be?
I am thinking hard... So any tape (different tape?) it will not play or record for but 17 seconds?
Jan 31, 2013 | Magnavox ZV427MG9 DVD Recorder/ VCR
My VCR-DVD magnavox ZV427MG9 A i get recording error, can't record +VR mode E 45
this is a similar problem with the same code http://www.epinions.com/review/Philips_DVDR3545V_37/content_464296251012?sb=1 The person in this says that the plastic "tab" on the back of the tape was broken off to keep from recording over it, but was unable to use it in a combo like you have. he put tape over the hole and it worked...Is this similar to what you are trying to do? let me know
Jun 11, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have...
I have a phillips magnavox Problem with the Philips Magnavox MWR20V6 DVD Recorder / VCR Combo I have a phillips magnavox vcr dvd recorder combo model number mwr20v6 that i have had fo about 2 years and here lately every time i try to record on to a dvd it pops up with error code e454037380.i have cleaned the lens with a disc cleaner and still didnt help,same thing is happening. i am also using the same type of disc that I have been since day 1. Can you help??
Mar 09, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Frigidaire Affinity ATF8000FS gives me an error code of E48. Stops a few mins after cycle begins
I have the same code and problem...E48:Board thinks the PTC circuit is closed. Any help?
Jul 24, 2010 | Frigidaire Affinity ATF8000FS
I have a magnavox mwr10d6 recorder. Errors keep coming up cannot record on disk e454037380
The disk might not have been finalized in the program that it was recorded on. If this is not the case unplug your recorder for 60 seconds and then plug it back in this resets the recorder.
Nov 12, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I'm getting the blinking locked door light and error code e48
e48 SAYS THAT THE MACHINE DETECTS THAT THE DOOR IS NOT LOCKED.UNPLUG MACHINE FOR 30 MINUTES TO SEE IF IT WILL RESET.iF PROBLEM PERSISTS,YOU MAY NEED A DOOR SWITCH
Nov 09, 2009 | Frigidaire ATF6000ES Front Load Washer
I have an error 25 on my dvd recorder
Technically, E25 is a copy-protection error, but I have some additional background on this issue. On the one hand, it could be a legitimate copy-protection error - you are trying to record from a copy-once or copy-protected source - this is especially true if you are trying to record from a Cable/Satellite Box that has a DVR box - since copying to the DVR is considered the first "copy," the Magnavox will not allow you to make a "second" copy.
On the other hand, Magnavox/Funai players see all programs recorded in V mode (as opposed to VR mode) as "copy-prohibited". It records all +R discs in VR mode automatically, so the solution in this case would be to record on a compatible -R disc (or vice versa).
There are two simple fixes for this issue in either case:
1) If you are using a +R disc, switch to a -R disc. If you are using a -R disc, switch to a +R disc. Simply switching the disc type will "fix" Magnavox recorders (long story).
2) If your TV has a "Video Out" or "Monitor Out" (most TV's don't), you can connect a yellow video cable from the OUT of the TV to the Video IN on the back of the Magnavox. This will permanently resolve your problem by fooling the recorder.
Here is additional info about the type of disc to get:
IDiscs that have been tested and are proven to be compatible with this recorder:
VERBATIM DVD+R 8x, VERBATIM DVD+RW 4x
VERBATIM DVD-R 8x, VERBATIM DVD-RW 2x, MAXELL DVD-R 16x, JVC DVD-RW 4x
IWe strongly recommend for good recording quality:
TDK DVD+R 4x/8x/16x, SONY DVD+R 4x/8x/16x, MAXELL DVD+R 4x/8x/16x, SONY DVD+RW 4x,
MAXELL DVD-R 8x/16x, MAXELL DVD-RW 4x
Good Luck!
-Tha Mp3 Doctor
Feb 01, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Magnavox error code
i get the same error code just putting in a dvd and hitting the record button
Aug 07, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Computers & Internet Logo
90 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
