Question about Kenmore Dryers
Our Kenmore dryer makes a beeping sounds while it is running. What does it mean? What should I do?
  • 331 Answers
Does the beeping start immediatly when you start it?
Posted on Jun 15, 2009
  • Raymond Ramirez
    Raymond Ramirez Jun 15, 2009
    I need a model number and a serial number. Ihow old is the unit and do you have an LCD that has a problem code on it?
How do i stop a Kenmore model 417880042700 beeps while drying and continues to beep when dryer not running?
Sounds like a touchpad/user interface issue...The buttons will push themselves and the unit beeps as if cycles are being chosen
May 16, 2016 | Kenmore Dryers
Model kenmore smart heat pack4 HE3 getting beep sound after some running
There is a test sheet under the front panel that tells all the diagnostic tests that you can run.
Aug 09, 2015 | Kenmore Dryers
Smart Heat Quietpack4. Why does it make a beeping sound after running for awhile?
Clean lint filter or the vent from the dryer to the outside for lint obstruction.
Kenmore model 84152/94152, 8 years old, started out with3 beeps over and over while running just fine otherwise. Now, 12 hours later, stupid thing started, while not running as in not in use, beeping once...
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Dec 31, 2017 | Frigidaire FEQ1442ES Electric Dryer
Kenmore Elite quiet pak 4 will not start. Close the door and hit the power button and nothing happens. Makes the beeping sound but nothing else.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jan 02, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore elite smart sensor model 110.6506 wont run
Many different possibilities. Could be thermal fuse, timer / control, motor. Start switch, or door switch. Most likely need to call service unless you have means to troubleshoot and test parts.
Nov 03, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer will not heat up
remove the plastic tab infront of the machine
start you dryer. look inside the hole to see if the igniter glows.
takes 20-30 secnds.
if it glows then move to the back side of the dryer
remove the screws an check the thermal fuse, for continuity is your tester has the beep sound wich is easier to use for newbies, try it no beep sound, no good.
but if it checks ok then you probaly have bad coils
also since you are looking onthe back make sure that the vent is not restricted, a restricted vent can cause blow back an shut the dryer off if the vent is not clearly open.
good luck!
May 25, 2009 | Kenmore 73952 Gas Dryer
Kenmore elite HE3
You need to check if the Spray Arms are knocking against an item in a basket. If the source of noise cannot be determined, run a program without plates or glassware. If the noises continue, let me know for further investigation.
Oct 05, 2008 | Kenmore 82822 Electric Dryer
Kenmore HE2 Dryer makes three beeps but wont start
Check your door closer switch. Mine was doing the same and it turned out to be as easy as changing the switch.
Mar 23, 2008 | Kenmore 62602 Electric Dryer
Open Questions:
Kenmore Elite Dryer HE4 Quietpak 9, has 4 dim lights showing on the console display but won't start or respond, I have bought brand new and replaced all sensors. Replaced heating element. looked like the original heating element. Pack came with new sensors. I did not test with a multimeter. My plan is to measure continuity on all the old sensors. Then do the same on the new ones. The electronic board looks good, does not smell burnt or old burnt smell. I cleaned all the lint in this dryer but unfortunately the motor has some lint in it which I surfaced cleaned. The only way to get to the motor is to remove the drum. So far I have soent $40 on all parts and a week works of troubleshooting as a novice. On the main display read, it shows two small dim lot red lines, wish I could send you a picture. Also when the fuse is off I plugged in the dryer and all the lights turned on normal. All looked in working condition except of course it did not turn on, I have not replaced the switch and with the new fuse, by the way, I bought 5 to 6 of the same fuses thinking I was burning them, that's why I bought a multimeter to retest them to see if they are not burnt. When I plug in the fuse it goes black but the door light works. I have held down the start button, nothing, held down the cancel button, nothing, I have done the crazy push all buttons even shook the machine a bit just in case something was causing whatever myth I was conjuring. I am about to give up and just buy a used one from someone else but I think I can fix this, it should be very simple to fix.
Aug 20, 2018 | Kenmore Dryers
Dryers Logo
113 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
