Question about General Electric WCSR4170D Top Load Washer
Water leaking from bottom - General Electric WCSR4170D Top Load Washer
My inglis dishwasher is leaking water out of the bottom of the door ftomiski@mts.net
The seal may well be "tired" and no longer seals properly. Get the serial number, make, model etc off the handbook or label on the back and call an appliance spares place or go online.
Dec 29, 2014 | Dishwashers
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Antifrezze leak on passenger side of van at bottom of motor
Possible intake leak and or water pump.If it following the lower hose it is a good chance the pump is leaking.It if follow ing the engine block chances are the intake is leaking.
Dec 06, 2010 | 2001 GMC Safari
I have a Inglis by Whirlpool washer and it has been leaking water. The water runs forward toward the front of the machine. What do I need to fix this?
you can check the drain valve and hoses leading to water level sensor, Is there any leakage from there or not. drain valve or a water pump, the rubber seals are usually frequent leaking of water out of there.
Jul 12, 2010 | Washing Machines
Washing machine leaking from underneath. All the connections from the back are secure but water appears to be leaking from the bottom. The leak started almost 24 hours after the washer was used. The...
I had the same problem. I have tried replacing the spring clamp on the drain hose with a regular adjustable hose clamp I got from the hardware store. Not real happy with this situation since I just bought this washer two years ago to replace a previous Kenmore washer that we had for nearly 20 problem-free years.
Apr 07, 2010 | Whirlpool Inglis IP4400 Washer
Can you tell me where my water pan is on my inglis defrosting fridge
There is a water pan or drain pan that holds the defrost water. After a while the heat dissapates the water so it should be dry.
It is located underneath the frig. Remove the grill on the front bottom and with a flashlight you should find it. Its either on the left or the right, since you did not provide the model number.
Mar 30, 2010 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
My inglis front loader washer is leaking at bottom of the door....inside rubber area near leak feels gummy....any advice??
Scrub the glass on your door and the rubber boot. This works in almost every case. The washer gets a build up of scum on these parts and doesn,t allow a tight seal. In rare instances you have to replace the rubber boot. Good Luck, Appliance Specialists.
Jan 04, 2010 | Whirlpool Inglis IP4400 Washer
Inglis washer won't agitate
Washer/motor runs but wont agitate or spin...this is often a broken motor coupler. See how to take apart info.
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
Apr 01, 2009 | Washing Machines
General Electric WCSR4170D Top Load Washer Logo
11 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Paul Bade
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
