Question about Sony Audio Players & Recorders
No sound from slv100
Volume button flashing
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
Your amp has DC Offset, meaning a blown amplifier. If you are interested in having your Sony repaired, please visit my website at audioserviceclinic.com. Thank you.
Posted on Feb 02, 2015
I have no volume no sound Would a Hard Reset fix this problem?
A hard reset is worth a try but it is unlikely to fix the problem, it sounds like a hardware issue.
Here are instructions for a hard reset
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Dec 25, 2014 | Craig CMP741d Tablet
How do I adjust the volume on a flash pad 2.0
To turn the volume off completely, press and hold the second top button from the left. (It's the spiral at the top of the Twist Me column.)
To reduce the volume, press and hold the third top button from the left. (It's the ship's wheel at the top of the Chase Me column.)
Do this when you first turn the game on. Be patient because it will take a few moments for the above volume buttons to light.
Nov 27, 2013 | Flash Pad 2.0 Touchscreen Handheld Game...
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Yamaha yas-101 uverse codes
I had the same problem with my U-verse s10-10 remote and a yamaha SR 300 soundbar. Here is how I got my volume control (but NOT power control) on the yamaha working:
First - always send volume control to the AUX button:
Press and hold AT&T key and OK for 1 second, release, look for 2 flashes.
Now press AUX button. The AUX button will show a long flash.
Second - Go through the manual programing steps listed in the guide for the AUX button (hold AUX and OK for 1 second, release; 2 flashes, punch in code). But instead of pressing the Power button to try to turn off your yamaha soundbar, press the volume up / down and Mute button. I think the code that worked for me was 4045 but I honestly don't remember.
The key is that you have to send the volume control to the AUX button first or it's all a wash.
Jun 26, 2012 | Yamaha YAS-101 Front Surround Sound Bar...
Trying to synch my remote to the new tvee model 25 sound bar and can't get the orange lights.
I had this same problem and it was due to their instructions which do not adequately explain the setup procedure.
On my own, I was successful in programming volume up but that was all. I assumed that for volume down I would hold the power button and the VOLUME DOWN button and wait for the flashing light just as I had for volume up. Problem is, you never get a flashing light.
Today, I spoke with a rep from Boston Acoustics who patiently explained that step one of the instructions has to be done the same way each time as it is the step that puts the soundbar into programming mode.
It is only at step 2 that things change.
The solution is to hold the power button and the Volume Up button every time in order to get the system into programming mode. Once the light is flashing, in order to program Volume Down, you then hold the Volume Down button until the light goes solid. Once the light goes solid, then press the volume down button on your remote 4 times slowly. Works like a charm.
Works the same way to program the mute button. Follow step one to get the unit in programming mode. Once the light is flashing, hold down only the mute button until the light goes solid. When the light goes solid, press the mute button slowly 4 times.
OBTW, this was programmed with a Logitech Harmony 650 remote unit.
Sep 05, 2011 | Boston Acoustics Audio Players & Recorders
THE RED ON /OFF BUTTON FLASHES BUT NO SOUND NO TV
check the speakers conection or the volume remote
Nov 09, 2009 | Samsung HC-R4755W 47" HDTV
Yamaha ysp-800 stuck on mute, volume indicator just flashes
Did you ever get a solution to this? mine is doing the same. i press the mute button and it says audio mute off but no sound still and volume indicator keeps on flashing.
Oct 03, 2009 | Yamaha YSP-800 System
No sound, volume knob is blinking
On the bottom of the remote on right side, right next to the master volume - key . it is actually called muting instead of just mute. Hope this helps.
May 05, 2009 | Yamaha RX-V690 Receiver
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Overall Problem - Panasonic RX-ED707 won't work properly at all
only 1 reason for that faults :
there is a flat connects the top panel which has all the controls with the other circutes in the stereo...
so you have to open it and care for the cd unit it damage easily then check the flat for loseness or cuts
it happened to me also and that works perfectly
good luck
Nov 14, 2007 | Panasonic RX-ED707 Boombox
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
